Old 09-22-2019, 08:22 PM   #1
Extension tire Valve problem on
On my 2018 Georgetown I cant get inside tire valve extension to take air. I can take pressure with gauge so it flows out but will not accept air. Am I doing something wrong?
Tncatfanforever is offline   Reply With Quote
Old 09-22-2019, 08:35 PM   #2
The extension may be loose.
AbdRahim is offline   Reply With Quote
Old 09-22-2019, 08:49 PM   #3
Can I tighten it without removing the tire
Old 09-23-2019, 12:39 PM   #4
The mechanic did it on my Forester. You have to reach in between the tires. I would just take it to a garage that does motorhomes.
Old 09-24-2019, 02:05 PM   #5
Hi Rider's Avatar
Send a message via AIM to Hi Rider
I also am interested in any responses to your issue. Every valve extension on my 2016 Forester 2401W MBS ultimately failed. The extensions would not respond to gauges when checking air pressure. Some would not take air. All now removed and that is after a flat that ruined a tire at 15,000 miles and a second flat at 24000 miles that also ruined a tire. Just put on six new tires and adding a TPMS system.
Hi Rider
Jack and his dog, Annie
2016 Forester 2401W MBS pulling 2006 Jeep Wrangler
2017 - 189 Days and 8,857 Miles
2018 - 193 Days and 7,024 Miles
2019 - 167 Days and 6,735Miles
Hi Rider is offline   Reply With Quote
Old 09-24-2019, 05:45 PM   #6
If you have any plastic extensions, throw them away.Steel valve stems and extensions are recommended for TPMS. Check out https://www.shinyrv.com/
tire, valve
