09-04-2015, 08:32 AM
Exterior flood light options
I searched the forums for ideas. Perhaps someone can help. Have a MH and the only exterior lights (other than the headlights) is the one over the door. I would like an option to have lighting at the rear and other side. We sometimes go out in the night , take the dogs out for a squirt etc.
Thought about getting a couple of lights and hooking into the door light switch, or get some 12V LED floods and wire in a toggle, or something. Could clamp a light on the latter and run a wire along roof, down in fridge vent to a switch. so many options. Any ideas or photos?
OR we use headlamps
I appreciate the input!
MarsMan
2015 Coachmen Prism 24J MBS
USN-R '01-present
09-04-2015, 10:03 AM
Go online and look at some 12V motion detector lights, some great ideas. I was thinking same thing, need a light on back of mh and mounts to ladder.
Bruce & Nancy Richardson
Lexington GTS 300 S/S
Chevy Avalanche
Jeep Wrangler
Honda Goldwing
09-04-2015, 10:13 AM
I wonder if there is a way to put a switch on our back up lights? they are LED and throw out a fair bit of light
MarsMan
USN-R '01-present
09-04-2015, 10:25 AM
Your backup lights are powered by your chassis battery, key would need to be on and vehicle would be in reverse. With motion detector you only need to run wire to a hot lead (battery). They also have battery operated detectors (4 C batteries)
Chevy Avalanche
Jeep Wrangler
Honda Goldwing
09-04-2015, 10:27 AM
Another thing to think about, if you have a hitch on back there should be one tab that maybe hot all the time.
Chevy Avalanche
Jeep Wrangler
Honda Goldwing
09-04-2015, 10:36 AM
Found one, look at Amazon, search for Swiftly Done. Solar powered motion detector
Chevy Avalanche
Jeep Wrangler
Honda Goldwing
09-04-2015, 12:03 PM
you can tie into any 12 volt light hot lead and run wires to a toggle and then to lights on other side of the same wall. I did this for some wall fans in my 5er worked great.
09-04-2015, 02:06 PM
Not hard to get 12 volts from house and feed through a switch to led back-up lights.
09-04-2015, 02:12 PM
Reminder, LED lights are directional, meaning a plus side and a minus side. Touch with 12 volts if doesn't light, touch other wire, should light then.
09-04-2015, 03:15 PM
I don't know about your MH, but in 5th wheels there are always enough ceiling lights that give access to the attic and to provide 12V to tap into. I have run satellite cable from one end to the other on several trailers.
Gary and Donna
2005 Cardinal 33TS-LX
Trail Air pin box
Center Point suspension
2018 Ram Laramie 3500 6'4" box 2WD
Demco AutoSlide 18k
09-04-2015, 04:53 PM
One of the best and most effective lights we have ever installed is the Starlight 1,000. (It replaces the porch light) Tied to the house batteries and it also tells you the condition of your batteries. (Blue flashing light/ good Red when they become low)
We just installed another one on our motor home and have installed them on a number of our travel trailers.
This replaces the ordinary porch light and you activate it for motion and it lights up at night. They run about $100 (led of course and they are directional up or down. Consumer ratings are very high.
Brandon2
2500 TS SunSeeker
09-04-2015, 05:08 PM
Brandon2
2500 TS SunSeeker
Brandon 2- I like this idea. I could put in on the rear and on the same switch as the current porch light. When it is on the rear light could be set on dusk to dawn or motion sensor.
MarsMan
USN-R '01-present
09-04-2015, 05:42 PM
Great idea for sure.
Chevy Avalanche
Jeep Wrangler
Honda Goldwing
09-04-2015, 06:06 PM
Bruce- Noticed you are in NH. We are scooting through Me.NH, VT on wat to Ontario- Decent boondocking places in your region?
MarsMan
USN-R '01-present
09-04-2015, 07:59 PM
Not a lot around here, I'm in West Lebanon, NH, right on the border of Vt. We have Walmart and Rest Areas that do allow overniters. Very safe area to overnight.
Chevy Avalanche
Jeep Wrangler
Honda Goldwing
09-04-2015, 08:02 PM
And if your in the area give me a call, maybe we can meet for a cold one or coffee. 603-298-5141
Chevy Avalanche
Jeep Wrangler
Honda Goldwing
09-04-2015, 08:14 PM
Depending on how much light you want... I used one of these on the back of my TH.
https://www.superbrightleds.com/more...54w/1272/2947/
We mainly stay at race tracks in fields where it to much light isnt a problem. But it is bright. You could walk the dogs or play a game of baseball....
2016, 3500 DRW,CCLB,CTD,G56,3.73
Work and play 40RLS,
PROUD OF MY USAF and ARMY SONS !
09-06-2015, 02:06 PM
Explorer
I have the Starlight and love it mine came with an LED for a few extra dollars.
I just finished putting flood lights and here is the post with pics
http://www.forestriverforums.com/for...hts-76385.html
I finished a 2 month trip using these often, they put out lots of light and hardly any power draw.
John
John
2011 Wildwood T26BHXL
2004 Yukon XL Denali
43yrs of camping; one lucky guy
10-05-2015, 09:04 PM
+1 on Starlight, had mine second year, love it!!!
