Old 04-08-2016, 09:10 PM   #1
Fake hardwood flooring... How to remove?
Is it attatched with glue? Loose? Thinking of installing quiet warmth heating film under.
Kuba is offline   Reply With Quote
Old 04-16-2016, 10:39 PM   #2
Go Pack Go!!
codespy's Avatar
My FR Wildwood did not have any glue when I replaced it last year....it was last loose everywhere.
1994 Damon Hornet 27R
2016 Wildwood 4092BFL (Still Getting Fixed by Dealer After Production)
codespy is offline   Reply With Quote
Old 04-17-2016, 07:44 AM   #3
shughey00's Avatar
Doubtful it is attached down...should be floating. The few I have replaced in my RV's are not attached. The exception is if it goes under a slide then in this case the edge under the slide will be.
Whether you can remove it and not damage it depends. Then again a great time to put in new if you like..and you have a pattern already from the old.
shughey00 is offline   Reply With Quote
Old 04-17-2016, 08:38 AM   #4
Guys, were your trailers old? My trailer is 3 years old. Its a salem cruise lite 26rks model.
Old 04-18-2016, 08:24 PM   #5
Go Pack Go!!
codespy's Avatar
Mine was a 2008....but I don't think it matters. Glue=additional/unnecessary cost. Unnecessary costs to manufacture RV=lower profits. Hence- I don't think you will find much glue for flooring in RV's.
Old 04-18-2016, 08:39 PM   #6
Wanna Be Camper
SaskCampers's Avatar
I had to have the floor repaired in a unit back in 2009 and the Service Manager told me the floors are glued around the edges only.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 04-18-2016, 08:45 PM   #7
Go Pack Go!!
codespy's Avatar
Luckily we had none in ours....and we had a 12' hallway on the edge/side of our RV and a living room with vinyl where the patio door is. No glue whatsoever. Guess we got lucky.
Old 05-06-2016, 11:07 AM   #8
Too Tall's Avatar
My fake hardwood is not glued but an easy way to tell is to test it with a vacuum cleaner. The vacuum will lift it if it's not glued. Mine lifts right up.
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
Old 05-06-2016, 11:21 AM   #9
cdangel0's Avatar
It's probably not glued. Due to the huge temperature and humidity swings inside an RV if it were glued it could swell and buckle.
Craig & Lynn D'Angelo
Delaware
cdangel0 is offline   Reply With Quote
flooring
