Old 04-05-2011, 09:12 AM   #1
mstell2's Avatar
Fan problems
I have a 2011 rockwood 8281ss with a ceiling fan and the light covers or globes keep falling off. Have not had one break yet. Does anyone else have this problem? How to remedy this problem? Thinking of looking for plastic ones or just not putting them back at all.
mstell2 is offline   Reply With Quote
Old 04-06-2011, 02:44 PM   #2
fivecodys's Avatar
Ok, I found one on line that shows the ceiling fan.
Does it use the two spring metal tabs to hold the globes on?
If so, maybe you can bend them a little to increase the tension.
If they use the three screws like a residential model then mabe some lock-tite on the threads but then if you have to remove them........???????
It's so hard to be helpful here without a good closeup view.
Can you post some pictures of them?
Bill
2009 Flagstaff 8528 RKSS
2007 Toyota Tundra DC 5.7L V8
Pullrite Superglide 14K
Air Lift 5000
Prodigy Brake Controller
"I've got a mind like a steele.. a......a steele......um.....uh...... what's that thing called again?
fivecodys is offline   Reply With Quote
Old 04-06-2011, 02:49 PM   #3
Herk7769's Avatar
No globes on mine either; but I have had them come lose on the bedroom fan. The globe retention screws strip out and will not properly tighten.
HAM CALLSIGN - KC3FFW
fan
