Closed Thread
Old 05-28-2019, 08:10 PM   #1
pburch
pburch's Avatar
Finally happened to me, blown Castle Rock tire
I read everyday about the "China Tires", but thought i would maybe get 2 - 3 thousand miles before I needed to upgrade.... WRONG! Just about to get on 95 north to get back to Melbourne FL - my wife decided we should stop and get a sandwich, as we pulled in the parking lot BOOM blew out a tire. Thank the good Lord it was there and not on the interstate!!! I go to change the tire, and the bottle jack died on me. Some nice fellow let me use his jack- there are still good people out there!!! Anyway, headed for new tires tomorrow..... I would like some insight on tires .... 2018 Hemisphere 282RK GLX - right at 8000# loaded - thinking of the Goodyear Endurance i have read so much about ...
What load range???
Presley
William Presley Burch Jr
Julie Ann Dyke Melbourne FL
2018 Forest River Salem Hemisphere 282RK
2018 Dodge Ram 2500 6.4 L 4 x 4 3.73 Gear 6' 4" Bed
Along with "Abby" and "Charlie" our dogs
pburch is offline
Old 05-28-2019, 08:34 PM   #2
larry2c's Avatar
Just curious, was your air pressure in the tire that blew where it should be before the blow out? Any sign that you might have picked up a nail or road debris that caused the blow out?
I just want to be outside!!!
'17 Salem Cruise Lite 210RBXL
'11 F150 5.0
Two shedding mutts
larry2c is offline
Old 05-29-2019, 05:37 AM   #3
Camper
I used Maxxis 8008s on my old trailer. They were good. I just put endurance on the current trailer a few weeks ago.
Those are the 2 most recommended brands right now. Whatever tire you choose to get make sure you upgrade the load range of the tire. If you currently have Load Range C then move to a Load Range D. If you currently have Load Range D then move to a Load Range E. This seems to be the most advised upgrade when it comes to tires.
The manufacturers use the load range that just makes the GVWR with not much reserve in capacity. I higher Load Range will give you more reserve and should prevent the tires themselves from being maxed out or even overloaded. Some surmise that this is the main cause of the china bomb phenomenon.
It is my understanding that the RVIA has recently upgraded their tire specs and now trailers are being delivered with higher load range tires.
Thanks,
Brian
TV - 2006 F350 6.0 DRW CC
TT - 2018 Wildwood 31KQBTS
Macrosill is offline
Old 05-29-2019, 05:50 AM   #4
ysidive
ysidive's Avatar
What load range???
Presley
I put Goodyear endurance on my trailer as soon as I brought the trailer home... So far in the last two years I have put about 10,000 miles on the tires and I am very happy with them.. Always check tire pressures for proper inflation... I never tow over 65mph... Another friend has used the Sailun tires and is also very happy with them I prefer the Goodyear because they are very good quality and made in the good old USA...
2018 Duramax 2500 LTZ
Freedom Express 281rlds
ysidive is offline
Old 05-29-2019, 06:21 AM   #5
D W
D W's Avatar
If I might ask, what size tires/load range were you running?
'04 K3500 Silverado LS with LS3 Connect & Cruise- with Intimidator Mods- Reprogrammed 4L80E
2016 Salem 27RKSS (Pacific Northwest Build)
D W is offline
Old 05-29-2019, 06:54 AM   #6
frank4711's Avatar
Watching .... always watching threads on Castle Rocks
Frank & Cindy *** 2019 Rockwood Ultra Lite 5ver *** 2019 Ram Big Horn *** Remi & Sage traveling Pomskies *** TST-507 TPMS *** Furrion Observation Camera *** B&W 18K *** Michelin Defender LTX M/S LT265/60R20 E rated *** 3.92 axle *** Timber grove Air Assist Springs ASAM *** 10 days camped 2019 --- Rockwood FOR SALE --- https://www.forestriverclassifieds.c...ood-2898ks-325
frank4711 is offline
Old 05-29-2019, 07:40 AM   #7
pburch
pburch's Avatar
Smile Finally happened to me, blown Castle Rock tire
Good morning;
Thanks so much for the replies!!!!
Yes, the tires were all aired up to 65#s, and I weighted at the beginning of my trip - 7280# on the axles - the only other affect could have been heat, as it was in the mid 90s - I usually don't pull over 60 MPH and especially now as my truck is new...tire size 225/75/15s steel belted radials load range D - 4 ply w/ 2 ply sidewalls. IMHO the tires coming on these trailers are not rated higher enough to perform under any conditions - I thought maybe I could get 2-3 thousand before upgrading, but not the case - only less than 1800 miles on these tires - Do what you want, but I would recommend tire change as soon as you drive from the dealer!!!!
Presley
pburch is offline
Old 05-29-2019, 08:01 AM   #8
REL
I swapped out my Castle Rocks in March before we took out TT out for the first time . I put Maxxis 8008s on...Found them on Amazon for a good price..Date codes were 2019.
REL is offline
Old 05-29-2019, 08:33 AM   #9
I suppose a class action lawsuit will someday put an end to the installation of Castle Rock tires on new FR products.
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
upflying is offline
Old 05-29-2019, 08:43 AM   #10
SilhouettePenny's Avatar
10 ply LR-E tires will make you happy. If you can find a Discount Tire store they sell Westlake and Carlisle trailer tires. Don't forget the spare.
2017 F350 Dually 6.7
2019.5 Hathaway
He who dies with the most tools, wins!
SilhouettePenny is offline
Closed Thread
tire
