Old 05-17-2012, 05:08 PM   #1
Finding HD TV stations.......
My 2011 Rockwood has a Wingard antenna for TV reception, and the TV inside has an HD tuner. Although we do not watch TV much, I have tried it, and found it to be a pain to find and tune a station.
I am adding a Wingman HD antenna to the Wingard to enhance reception, but I am wondering what people do when they reach a new site to try and quickly find and tune to local stations with their RV mounted antenna????
Do you search somewhere on line to find local stations and then use a compass to point the antenna?
Just wondering.......
2021 (Dec) Dynamax Isata 30 FW Xplorer
toshu is offline   Reply With Quote
Old 05-17-2012, 05:34 PM   #2
GASPEDDLER's Avatar
Channel Search...
2012 F-350 4x4 King Ranch Super Duty CC 6.7 Turbo Diesel 3.55 e-locker
2011 Palomino Puma 30KFBDS with Side Paw Kitchen and Bunkhouse
Equalizer E2 Hitch
GASPEDDLER is offline   Reply With Quote
Old 05-17-2012, 05:45 PM   #3
Originally Posted by GASPEDDLER View Post
Channel Search...
do you mean the option on the TV for searching channels??
If so, I have done this and gotten zilch. I assume that an antenna is somewhat directional and pointing it at the station will help you get the best signal
Old 05-17-2012, 05:46 PM   #4
TURBS's Avatar
like gas said do a auto tune on tv for stations . you may have to turn antenna several directions to pick up stations aimed that way.
your antenna booster is on to right ?
Old 05-17-2012, 05:57 PM   #5
yep, I turn the booster on....
I was hoping that perhaps there was a more "scientific" way of finding stations....
Old 05-17-2012, 05:58 PM   #6
Steeljag's Avatar
As stated above ......booster on.......channel search........beer.........sit back and enjoy after coming in for the night !
1930 lbs CCC
2014 Jeep Rubicon JK
Steeljag is offline   Reply With Quote
Old 05-17-2012, 06:02 PM   #7
TURBS's Avatar
Ok lets step back and survey .......
1) Your for sure you have an hd ready tv ?
2) Are you assuming that the cabling is correctly hooked up "has it ever worked"?
3) Are you on the right aux according to where your antenna cable is hooked up ?
3) Is your tv set to cable and not over the air ?
IF you cant even get a glimse of a tv station then a wingman may not help do to other issues .
When I auto tune on mine I get 30 + stations as far away as 75 miles .
course I live in the midwest its flat .
And I have stock antenna as you do .
Old 05-17-2012, 06:09 PM   #8
yeah..it does pick up stations. Got loads at the dealer, then 3 weak ones at home. I guess since I do not watch TV at home, I am not patient about turning the antenna to find the best direction to "find " stations. ....... plus I am an engineer/scientist, so I was looking for an "easier" way
Old 05-17-2012, 06:13 PM   #9
Herk7769's Avatar
http://www.forestriverforums.com/for...ster-7037.html
http://www.forestriverforums.com/for...uard-5152.html
Also I did this mod (not my invention BTW) and highly recommend it unless you upgrade your power supply wall plate to the new one with a signal strength meter.
I use www.antennaweb.org to find local stations.
File Type: pdf Protractor used to align TV antenna.pdf (219.7 KB, 121 views)
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 05-17-2012, 06:39 PM   #10
AWESOME!!!!!
this is exactly what I was thinking of!!!
I did find that Antennapoint.com has more stations listed for my home address that antennaweb.org, so both can be used and compared.
Not sure I will mount the protractor, but I will get one and play with it and a compass.
Old 05-17-2012, 06:47 PM   #11
member
:SureLock Digital Tv Signal Finder I just bought this last night hope it works i'll let you know when I use it
2019 Cedar Creek Silverback 31IKS
2017 F 250 6.2 gas 4.30 8' bed
HIDE OUT is offline   Reply With Quote
Old 05-17-2012, 06:52 PM   #12
woodsman's Avatar
My scientific way is looking for a neighbor who has his antena up. I point mine in the same direction. I use a converter box which picks up many digital and analog stations. Sometimes twice the stations as antena alone. Do not know why this works but it does.
woodsman is offline   Reply With Quote
Old 05-17-2012, 06:57 PM   #13
I've done the same thing every time we camp. Recently I've installed the Winegard SensarPro TV Signal Meter and it works great. Purchased it from Campingworld and it was pretty easy to install in place of the regular tv booster outlet. I simply turn it on(tv off) and signal strength numbers are shown on the meter. You just turn the antenna to the strongest numbers, then turn on your television and do a new channel scan. I'm impressed how good it works. It has an adjustable gain control that helps too. Camping keeps getting better and better!
2006 Rockwood 8272S
2005 Chevrolet Silverado
John & Pandra
Battlefield, Missouri
F.R.O.G. Member
1st International F.R.O.G. Rally Branson Missouri
JohnandPandra is offline   Reply With Quote
Old 05-17-2012, 06:57 PM   #14
what do you mean exactly by converter box??
Old 05-17-2012, 06:58 PM   #15
Herk7769's Avatar
AWESOME!!!!!
They break easy when drilling the handle hole and cutting out the center bar. I broke 2 before I got it right.
Old 05-17-2012, 07:01 PM   #16
That looks VERY interesting and not that expensive.
By all means give us a report here in the thread to educate us on this device!!
Old 05-17-2012, 07:10 PM   #17
Herk7769's Avatar
Winegard SensarPro TV Signal Meter - Winegard RFL-342 - Over-the-Air Antennas - Camping World
This is what I was referring to.
Old 05-17-2012, 09:14 PM   #18
Coops1's Avatar
I've used TV Fool for finding towers in the past, works in Canada as well.
26WRB - V-Lite
Denali HD LML
Coops1 is offline   Reply With Quote
Old 05-17-2012, 09:23 PM   #19
wow...thats an even more powerful tool, although it lists many stations for me that are beyond my capability to capture....
Old 05-17-2012, 09:34 PM   #20
cootr68's Avatar
If you have an Android phone TV antenna helper is a good app. It uses your GPS location to find towers/signals near you and also has compass feature.
1997 Sierra m-27fls tt
1999 Pontiac T/A
2006 flstn Deluxe
2004 Polaris 330 magnum
Bear the Labrador
cootr68 is offline   Reply With Quote
led pad
