I have the same system on our Lexi, from the factory. Fortunately, have the install/owners manual.
Firestone recommends a minimum of 5 psi, and a maximum of 100 psi.
You really don't want to run them empty or near empty as they will take a beating (think of a squished tube in an underinflated tire), or over inflated as it will give you a rock like ride.
Remember, the airbags are not there to increase your load capacity, but to level and stabilize the rig. They won't increase your load capacity.
Just play with the psi settings till you get the ride your looking for. On our Lexi 283ts I have found the best psi is 70-75 when I'm running loaded.
A few things to be aware of...
The bags themselves are small, about the size of a gallon paint can. They will fill up VERY fast, a matter of 10-15 seconds. and if your not careful you'll pop them. When adding air, just blip them a second or 2 at a time.
They will lose a bit of air over a period of time, maybe 5 psi over a 2-3 week period. Nothing to worry about, it's just a rubber bladder and like a tire, will lose a bit of pressure.
Grumpy
Steve & Cheryl + Zoey, and Ziggy, our furry kids.
2012 Forrest River Lexington 283ts
Toad, 2013 Subaru XV Crosstrek
