Old 03-22-2019, 11:43 AM   #1
First doubt of FR build quality
We have been very satisfied with everything about our 2018 2104S until yesterday. I installed a digital thermostat and was pleased to see the industrial quality closed end crimp connectors as I am not a fan of wire nuts for permanent connections . Unfortunately they crimped them with what looked like pliers and these need to be crimped with a Klein type of electrical pliers. One wire came out of the connector when I pulled them out of the wall and the other 5 pulled off easily by hand. Picture attached. This is a 12 volt system by I am now concerned about every wire this person may have crimped especially on the 110 volt. I will look behind the fuse box and look for more of these.
Okmechanic is offline   Reply With Quote
Old 03-22-2019, 06:43 PM   #2
When we first got our RV we put something in the front storage and banged a wire those crimps I came right apart. The reason I found out we banged the wires because the landing gear did not work and then figured out thatís what it was. I have the wires protected now. They were exposed before.
quick83 is offline   Reply With Quote
Old 03-22-2019, 06:53 PM   #3
Head Rambler
I don't like those connectors in production assembly, simply because it's so easy to not crimp them correctly. I'd rather have wire-nuts in that scenario. They're prone to not having the wires inserted correctly, but they're not prone to bad crimps.
I've changed all the crimp connectors on our RV to lever connectors, because, as you did, I found several that weren't crimped correctly.
Gotta go campin!
Old 03-22-2019, 07:04 PM   #4
I hate those connectors as well. The best are heat shrink crimp connectors with built in sealant. You of course need to use a quality crimper. Just don't solder...worst thing you can do on an RV with all the vibration. On second thought, wire nuts are worse than soldering. They are not be used in a vibration environment either.
Wire Connectors Marine Grade Wire Heat Shrink Terminals, Lugs, Battery Terminals Genuinedealz.com
https://marinehowto.com/marine-wire-termination/
https://shop.marinehowto.com/product...nal-crimp-tool
2017 Coachmen 233RBS
2018 Ford F150 Lariat 3.5 Eco
"Common sense is not very common"
babock is online now   Reply With Quote
Old 03-22-2019, 08:11 PM   #5
This type of connector is an industrial standard where wire nuts are prohibited. They are very reliable if crimped properly. The final test is to give each wire a good pull to verify all wires are crimped. These connections were poorly made and I wonder how many heart aches this person caused with his poor craftsmanship. Gives the company a bad name. Hard to find good skilled labor now a days.
Old 03-22-2019, 08:53 PM   #6
Jayhawker
Jayhawker's Avatar
Here are the T&B Sta-Kon pliers we use in the electrical trade. Very high leverage crimping tool.
Jayhawker is offline   Reply With Quote
Old 03-22-2019, 09:19 PM   #7
Thatís the proper tool!
Old 03-22-2019, 09:44 PM   #8
wmtire's Avatar
Moderator Hat on:
The site team has edited posts here that do not adhere to our friendly forum guidelines:
Customer Disputes: This forum is not intended to be a mechanism for people to solely vent frustrations about services, products, vendors, or sales. Please settle your differences with the seller, provider, manufacturer, or dealer through other means but not through our community. You may post about problems you have with Forest River products in an effort to learn from others with similar issues, however the use of the forums to repeatedly attack or bash Forest River, Forest River products, or Forest River owners is strictly forbidden.
The above guideline also applies to calling FR employees names, who we are fortunate enough to have some on these forums who volunteer their time and effort to attempt to help.
The site team will delete or close threads/posts that do not keep these forums friendly and constructive.
Please feel free to contact myself or any of the other site team members thru the forum private message function if you have any questions/concerns.
2011 Flagstaff 831 RLBSS
Did you know, according to Google: Pepsi was once the 6th largest military in the world?
Old 03-23-2019, 09:08 AM   #9
Check your 7 pin connector junction box under the front of the trailer. Mine was full of these. I put a new cord on to get a little extra length and every connector pretty much fell off in my hand.
deepseadan is offline   Reply With Quote
Old 03-23-2019, 09:28 AM   #10
In my 2018 Cherokee all the junctions for the 120V system is push connectors. Had a neutral fall out of one our first season and it took out most of our 120v outlets.
TheWolfPaq82 is offline   Reply With Quote
quality
