Old 10-11-2010, 04:56 PM   #11
rockin'ray's Avatar
No, I drained the hot water tank by removing the anode and then with a small long wand and wet vac sucked out as much of the remaining water that I could. I used the bypass valves on the lines to bypass and pump the pink stuff through the rest of the plumbing.
rockin'ray is offline   Reply With Quote
