Old 04-01-2011, 05:48 PM   #1
wfmdfm's Avatar
First Time out and the front jacks wont work
Well we just arrived for our first trip in the new Flagstaff 8528RKWS. Backed in and went to disconnect from the TV and the front legs wont extend. I checked the fuse and it looks good. Is there any rest or safety that I am missing. I can use a hand crank but will need to remove one of the gas tanks to insert the crank. Any Ideas would be helpful. The dealer is already closed so we are unable to ask them. HELP--
2011 Flagstaff 8528RKWS
2015 Toyota Tundra
wfmdfm is offline   Reply With Quote
Old 04-01-2011, 09:20 PM   #2
Dave_Monica's Avatar
When you hooked up when you left...if you ran the landing gear all the way up to the stop, the fuse will probably be blown (don't ask me how I know). This is the in-line fuse between the the landing gear drive motor and the postive terminal on the battery. Even the fuse looks OK, replace it and try it out...I believe that it's a 30A fuse.
Good Luck,
Dave
Old 04-01-2011, 10:12 PM   #3
Location: Canandaigua,New York (The heart of the Finger Lakes)
Dave, now how do you know ???? Did you do this ???? lol
BigRed is offline   Reply With Quote
Old 04-01-2011, 10:17 PM   #4
Everybody has done it once. Personally I cost me a new landing gear motor. Never again. I fixed it so I don't have to worry about that mistake.
Old 04-01-2011, 10:25 PM   #5
Wasnt meaning to offend Dave..............I for one cant talk. I just always laugh because it sounds like me when giving some advise. I always end with...Dont ask how I know!
Old 04-02-2011, 04:19 AM   #6
Herk7769's Avatar
Happened to me as well.
Behind the battery in my 5th wheel were 3 green 30 amp fuses.
Change all three with 30 amp auto-reset fuses from the car store (AutoZone or whatever).
The other two were for the main slides.
Initially I just changed the landing dear fuse, but after I had to remove the battery box a second time to change a slide fuse that popped when ice formed around the seal, I did them all.
HAM CALLSIGN - KC3FFW
Old 04-02-2011, 07:10 AM   #7
DAISY BOYKIN's Avatar
Landing gear
I may be wrong, but if I remember right on my Rockwood in Jan 2011 PDI, I was told the circuit breaker was just behind the battery box. You had to push a reset button on the bottom.
Again, I may be wrong!
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 04-02-2011, 07:25 AM   #8
wfmdfm's Avatar
Found
Thanks for the input. I found the 2 fuses to the right of the battery. One was blow. Now I need to pack a box of spare fuses. I will also mark the legs so I stop before reaching the end of travel. Seems like a cheep fix for them to add some type of stop rather than tax the motor and fuses.
Wally
2015 Toyota Tundra
Old 04-02-2011, 09:18 AM   #9
Arn
Arn
My jack had the same issue. I replaced the fuse with a self resetting circuit breaker. Now if I extend or retract too far, I just have to pause for a second while it resets & then I'm good to go. It's a lot cheaper in the long run than replacing fuses every trip & a lot easier than marking stop points!
Arn
Arn is offline   Reply With Quote
Old 04-02-2011, 10:24 AM   #10
Same thing. A 20 amp fuse isn't big enough. Wayne
wayne anthony is offline   Reply With Quote
