Old 09-20-2010, 08:50 PM   #1
flagstaff hw27sc sink wont drain
Just bought unit used and sink wont drain without dump valve open. I verified 6.5 gallon tank. Checked vent stack in cabinet near sink bowl and replaced for good measure and still wont drain. If I unscrew the stack vent until it lets air out around the threads, then it drains. What am I missing here?
camper carl is offline   Reply With Quote
Old 09-20-2010, 09:48 PM   #2
Sounds like your main vent is clogged on the roof look in it and see if it has a blockage
Yankees is offline   Reply With Quote
Old 09-20-2010, 10:09 PM   #3
BigDTx's Avatar
is the tank full it is trying to drain into?
BigDTx is offline   Reply With Quote
Old 09-20-2010, 10:33 PM   #4
On some Flagstaffs the vent is under the kitchen window in an area close to the sink on the outside. Make sure you don't have a dirt daubers nest clogging it.
2006 Flagstaff 831RLSS Travel Trailer
2007 Chevy 2500HD 'Classic' with the Duramax engine.
Converting a 1956 GMC PD4501 Scenicruiser, ex Greyhound into a motor home.
jackhartjr is offline   Reply With Quote
