Old 04-27-2011, 10:36 PM   #1
Terry & Melanee
Flashers not working - can't find relay.
Hi all!
We are newbies starting out with a 2000 Georgetown and figuring out the pros & cons. So far we love RVing and our Georgetown. Problem is we can't find the relay for the flashers. Anyone have any ideas where it might be?
Thanks in advance!
Terry & Melanee (CozyMels)
cozymels is offline   Reply With Quote
Old 04-28-2011, 07:25 AM   #2
Hello and WELCOME. As for the flasher, I think a Georgetown is on a Ford F53 chassis. You can go here: http://www.motorcraftservice.com/vdi...d=&kevin=rules
On the left side of the page, look under owner manuals. Then select year, etc. Hope it helps.
One other thing to always check, make sure the 4 way flashers are working. Sometimes if they don't work, the switch will get turned on, and this will cause the regular flashers not to work.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
