Old 07-23-2011, 08:56 AM   #1
Unhappy Flushing RV tanks at CG.
So I have been reading through the forums and see no answer to my questions.
What do you guys do when dumping at a CG and their flush hose that are hooked up to the towers, only have a spray head on them, no hose connectors. My 5er has a hose hookup for rinsing Black tank and there is no hose hookups at the dump station. I think I have been to maybe 2 CGs out of many that actually had hose hookups.
When I dump, I like to flush out tank and add a couple of gallons of fresh water before traveling to slosh around and help keep clean. Many times we don't have fresh water in the fresh water tank so I can't use it to fill or flush.
I tried one of those water thief adapters and they are too big to fit over a 1/4' pipe like on the rinse out hose at the CGs.
2005 Rockwood 8283SS 5er. 1999 Ford F250 Super Duty 7.3 Diesel, extended Cab. 2 dogs and a wife!
Gregad is offline   Reply With Quote
Old 07-23-2011, 10:19 AM   #2
Villa Estate 392FLFB
The_Stuff's Avatar
need to get is a garden hose adapter.
3/4" to garden hose is probably what you mean. 1/4" is tiny
One state/province at a time!
The_Stuff is offline   Reply With Quote
Old 07-23-2011, 04:48 PM   #3
That gives me a idea. I have seen a lot of them with just a 1/4" pipe on the end of them and a few with like a yard sprayer nozzle on them. But yes, if I use an adapter like the one you posted, I could put a piece or rubber hose on the end and squeeze it around the pipe piece.
Old 07-25-2011, 09:33 AM   #4
I put a few gallons in the fresh water tank so I can add clean water when I am done flushing. Works well as long as I remember to do it before disconnecting the water at the site
2011 Coachmen 292 bhds
2005 Silverado 5.3 L w/ 4:10 and Equal-i-zer
Eric, Heather and Elaine Higgs
TopGobbler is offline   Reply With Quote
Old 07-25-2011, 10:57 AM   #5
During the season I will just add about five or so gallons of fresh water after dumping, by the internal system or my fire bucket, redump followed by a few gallons of water and chem to wash about on the way home after the redump. Every couple trips I get a site with sewer and do it up right on my site. I treat the water hose at dump stations to be about as clean as the inside of my sewer hose since I have seen people put them in theirs, so I tend not to use them. I suppose you could carry a short piece of dedicated hose to use at the station but the time it takes to hook up could be an issue.
2007 Georgetown 373
Nutmeg is offline   Reply With Quote
Old 07-25-2011, 11:18 AM   #6
I learned a long time ago to get them as clean on dumps as possible. Had one I thought was cleaned out and ended up with a plugged tank as some waste got caught behind the closet pipe and let loose when I moved down the road. Now I like to flush it then add a gallon or two of water with water softener powder in it and travel to fully clean it out. I liked the Tornado rinse as it spins around and gets behind the toilet pipe and flushes stuff off the sensors I mounted it on the back side away from the drain hole so it washes towards the drain. I made up an adapter this morning with the idea The_Stuff gave me and already tried it out. Works good with soft rubber hose to squeeze around the water tower pipe/hose.
Old 08-02-2011, 10:19 PM   #7
I sometimes add a bag of crushed ice to my black water tank after flushing. It sloshes around on the way home and I think helps keep the tank clean.
Flyboy740 is offline   Reply With Quote
