Old 05-28-2019, 01:39 PM   #1
cardwellmarty's Avatar
Foam Air Conditioner Filter Replacement
I purchased new foam filters for our Dometic Air Conditioner but foam material want let much air through, found some at Lowe's for window units that is a little better but not like the one l am currently now using in the A/C. No problems with the one l am currently using but when l try the new filters they cause the A/C to heat up and flip the 20 amp breaker, l cleaned A/C coils early spring, l try to keep the A/C maintenanced. Plenty filters to choose from on Amazon or Ebay but what are y'all using that works good?
cardwellmarty is offline   Reply With Quote
Old 05-29-2019, 12:58 PM   #2
Failure is my business
2Evil4U's Avatar
I use the originals that came with my Colemans. They flow well, clean easily, and after 3 years of use the coils still look good. Why do you need to filter that fine? These units really need as much airflow as possible.
Current vehicle list: 17 RAM 3500 4x4 Cummins Aisin 4.10, 16 Flagstaff 832IKBS, 14 RAM 1500 4x4 Hemi 3.92 Bilstein 5100's Derale oil cooler, 97 F150 4x4 5.4L 278,000 miles, 80 Firebird Esprit Aussie Burnout Car https://youtu.be/v06VjII7HmE, 78 Harley Davidson FX 79,000 miles dad bought new, 71 El Camino ZZ3 TH400 12-Bolt, 37 Ford 3 window 502 Chevy dad built
Days Camped: 2016: 43, 2017: 83, 2018: 44, 2019: 78
2Evil4U is offline   Reply With Quote
Old 05-29-2019, 02:46 PM   #3
That's my problem all that l have ordered are to fine, l am having a hard time finding one that will let as much air through but still do a good job catching dust. I have one in now that is working well but l can not find any more like it.
Old 05-29-2019, 02:54 PM   #4
Bluepill's Avatar
Quack, quack:
https://www.amazon.com/Duck-Replacem.../dp/B002GKC2US
Old 05-29-2019, 03:04 PM   #5
Citrus County, Fl.
GL1800Rider's Avatar
These are the ones I bought from Amazon and so far they seam to be the same as the original one.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
GL1800Rider is offline   Reply With Quote
Old 05-29-2019, 03:11 PM   #6
Originally Posted by Bluepill View Post
Thank you
Old 05-29-2019, 03:12 PM   #7
Originally Posted by GL1800Rider View Post
These are the ones I bought from Amazon and so far they same to be the same as the original one.
Thank you
Old 05-30-2019, 02:56 PM   #8
Villagerjjm's Avatar
I saw some replacement filters at Walmart in the RV section today while walking through.
Villagerjjm is offline   Reply With Quote
Old 05-30-2019, 11:17 PM   #9
Hank
What I did was to install 8 X 10 metal filter frame and mounded it over the original filter. I cut my own filter out of a larger piece of good quality filter material. Better filtration and better air flow. You have to make a larger frame out of wood or vinyl(I used Vinyl) to mount the metal filter frame in. Works good last a long time.
Hank
Henry Barnes is offline   Reply With Quote
Old 05-31-2019, 09:04 AM   #10
Hank
Good idea, if and when you get a chance could you take a few pictures of open, of filter and how you mounted it on the inside? I am going to use your idea. Thanks Marty
Old 05-31-2019, 03:13 PM   #11
Hank
These are some pictures you requested. I made the frame out of vinyl(1.5 X 3/4" material) Unit is mounted with 2 screws from top through the original filter frame. A wire mesh is inserted to support the filter material. You can purchase the filter material on line in 24-36" length. If you were to need additional info I may have a drawing of the vinyl frame.
Hank
Old 05-31-2019, 04:19 PM   #12
Hank
Thank you, this is such a good idea, l appreciate all the info.
air conditioner, replacement
