Old 03-26-2016, 01:33 PM   #1
Followup on warning about plastic valve extensions
Some of you may have read my rant about the dangerous practice of FR using plastic valve extensions that break.
What good is a rant without a solution?
Just for an emergency/short period use, I had the also infamous braided extensions installed. That bought me the time to order the "kit" that permanently fixes the leak and filling the inner dual problem. BTW, one of the extensions started leaking within a day.
As you can see from my signature, having rear duals (with filling/checking problems) is not new to me. The link below, is the same "stuff" I have used for my duals for about 500,000 miles of RVing.
DL1F Brass Duallyvalve Kit
I have NO affiliation/connection/financial interest or any thing other than being a customer with this company. BTW, if you are concerned, check their parent company, Borg Supply company.
With no connecting point to leak the problems go away. They will EASILY accommodate a TPMS as well because the inner valve stem is PROPERLY supported.
I am trying to get the Discount Tire Co store in St. Augustine to carry them as they treated me very well and only charged $85 (with tax etc) to dismount all 4 rear tires, install the new valves, re-mount and re-balance all 4 rear tires. From what I see others paying, this seems extremely reasonable. If interested, PM me.
Paul
1992-94 1983 Fleetwood Jamboree Rally class C
1994-99 1995 Holiday Rambler Endevor LE class A
2000-03 2000 Custom Monaco Windsor class A
2003-12 1997 Blue Bird Wanderlodge WB 43 class A
2016-17 2016 Forest River Forester 2801 QSF class C
2017 2018 Renegade Verona 36VSB Super C
AncientMariner is offline   Reply With Quote
Old 03-26-2016, 02:18 PM   #2
RETIRED
n-e-d's Avatar
Dont know if the plastic extensions your talking about are the same as my AirFlexx inside dually extensions but they came as original equipment on my Sunseeker. I was loosing air thru them so I went to solid metal-too heavy, braided-didnt care for them and back to the AirFlexx. I found that with the rubber extension stabilizers(like the ones in your attachment) I lost 5# over the winter in one dually nothing in the others and after a 4hour "gotta get behind the wheel" spring fever ride lost none in any tire. The AirFlexx are suppose to be pressureless and have a metal inner tube..
Mary and Me
2015 2650s "Finally"
2015 Jeep Cherokee
2016 Ford Race Car Red 350HD Cargo Van HR DRW EXT DIY Daytripper "My Little Red Corvette"
n-e-d is offline   Reply With Quote
