Old 11-11-2015, 08:14 PM   #1
Steveanddianne's Avatar
ford 2016 450 stuck in park
We have 1000 miles on our RV have not taken a trip yet and can not get it out of park. Was told it could be the brake shift interlock. We know it must be repaired but don't want it towed. First we were told it is under the black plate under the steering column (below ignition), then in front of it the lick plate which I believe is the long strip of dash behind the steering wheel and above the brake - we are totally confused. If it is the lower panel, we can find the screws to remove it. thanks, we are frustrated new RV'ers.
Steveanddianne is offline   Reply With Quote
Old 11-11-2015, 08:17 PM   #2
Kenny kustom's Avatar
Do you have battery power?
Key on?
Do the brake lights work?
2015 RAM 3500 CCSB CUMMINS
2016 Sabre 36QBOK
2017 Dynamax Isata 4
Old 11-11-2015, 08:21 PM   #3
Yes we have battery power, the key is on and the brake lights work. Thanks
Old 11-11-2015, 08:22 PM   #4
Iwannacamp's Avatar
I assume you are pushing the brake?
Did you try turning the wheel fully one way or the other. It might possibly be jammed. Especially if against a stop or something.
Both cheap checks
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Old 11-11-2015, 08:24 PM   #5
Yes - we are pushing the brake and the wheels turn. We drove it home from the dealer and this was the first time we were going to use it.
Old 11-11-2015, 08:24 PM   #6
Iwannacamp's Avatar
One other cheap check...apply or release or both the parking brake.
2017 Puma 297RLSS
Old 11-11-2015, 08:24 PM   #7
Both cheap checks
My immediate thought. Turn the wheel and while holding it turned, see if it will shift.
2017 Ford F450 Lariat 6.7L
2016 Vengeance Touring Edition 40D12
Former Forest River Campers:
2004 Puma 30FQSS
2010 Sabre 31QBDS
2014 Work & Play 30WRS
KFX450RXC is offline   Reply With Quote
Old 11-11-2015, 08:30 PM   #8
Is it very easy to get to and release the brake shift interlock, or not something we should not attempt?
Old 11-11-2015, 08:40 PM   #9
Iwannacamp's Avatar
You can google it. I did. I assume it is column shift? Or floor ?
Name:	ImageUploadedByForest River Forums1447296036.183225.jpg
2017 Puma 297RLSS
Old 11-11-2015, 08:41 PM   #10
Iwannacamp's Avatar
The top info looked promising. Click image for larger version
Name:	ImageUploadedByForest River Forums1447296112.585254.jpg
2017 Puma 297RLSS
ford
