Old 03-02-2010, 09:11 PM   #11
NWJeeper's Avatar
Originally Posted by windrider View Post
I hope you are installing a relay to power the compressor, and know how to wire it in. If not, let me know, and I'll try to get a diagram.
I did the same kit last year. It does not need a relay as the compressor is very small. All required parts are in the kit. Wolo810 for reference.
Ed & Wendy
www.nwjeepn.com
Old 03-03-2010, 08:15 AM   #12
betndavrv2's Avatar
Windrider.....I'll take all the help I can get. Thanks
betndavrv2 is offline   Reply With Quote
Old 03-03-2010, 11:16 AM   #13
Glad to help, and hope I can help. Suggested blower circuit as most people don't use this on first start, unless they are scrambling for AC. Also has a little cushion on amperage. If you check the website I posted earlier, and check the manual, pages 69 thru 70 something, you'll find the fuse boxes, and fuse, with circuit descriptions. Another switched circuit would be the wipers. Let me know if you need anything else.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
