Old 04-27-2010, 07:05 PM   #1
Forest River Electricial no no..
Found this blue wire nut behind my power converter. These are all the D/C negatives (9) from all my circuits. Look closely, at the one wire that comes from the wire nut and goes into the converter. This one 12 AWG wire is supposed to handle all the negative load. When I removed the tape, the wire nut just fell off. Luckly there was enough length on the wires to put them under the terminal screws in the converter where they belong. I havent had any problems yet but could have been a headache later on.
If you find a blue wire nut with a bunch of wires, you'd be better off in the long run to make the connections more sound. Blue wire nuts are for larger wires not 10- 12AWG wires.
railrode is offline   Reply With Quote
Old 04-27-2010, 07:12 PM   #2
Grape Escape
This type of workmanship meets RIV or whatever approvals RV manufacturers supposedly meet????????????
One day...................
2008 Cardinal 30RKLE 5th wheel sold
2006 Rockwood 2607, 2001 Traillite
55 nights 2009, 53 for 2010
44 for 2011, 38 for 2012, 35 for 2013, 51 for 2014
dezolen is offline   Reply With Quote
Old 04-27-2010, 07:43 PM   #3
NWJeeper's Avatar
Yeah, that's not good at all. Good catch...
Ed & Wendy
www.nwjeepn.com
Old 04-28-2010, 11:31 AM   #4
Time to check our wiring. Thanks for the heads up.
Bob and Teresa is offline   Reply With Quote
Old 04-28-2010, 03:57 PM   #5
KyDan's Avatar
If I were you, I'd call forest river and make sure I had a supervisor.
I'd tell him what you found and send him the picture via e-mail.
This is absolutely NOT code and the guy on the assembly line
needs a time out!!
Seriously.
I've had my converter out to install a battery disconnect and
so I know my white wires do go to the buss bar and not
like your photo thankfully.
Our trailer was an RV show trailer and it sat with EVERY light
on for 7 days. Most people would never do that.
I think you could likely over heat that single lead
with every light on at once.
Peace!
Dan & Rita D
Blue Ox WD hitch
KyDan is online now   Reply With Quote
Old 04-28-2010, 05:10 PM   #6
tmmar's Avatar
Hopefully that is not an everyday occurrence. Maybe it is was just a newbie on the line.
Tom and Margaret
2014 Berkshire 390bh-60
Old 04-28-2010, 06:27 PM   #7
I do not think this is unusal,don't think it is proper.On ours they cut the #6 neg. wire from battery to convertor,wire nutted the 2 ends of #6 together with a piece of #12 and connected all negative wires to tail of #12.I mounted a ground bar on wall connected all wires to it.This helped with dimming and flickering of 12v lites.
Dave&Eileen
bdb2047 is offline   Reply With Quote
Old 04-28-2010, 07:17 PM   #8
Steeljag's Avatar
I agree with photo's and sending the pics and this info. to both F/R and your dealer!!
1930 lbs CCC
2014 Jeep Rubicon JK
Steeljag is offline   Reply With Quote
Old 04-30-2010, 08:08 PM   #9
Knower of Some Things
It's not the dealer's fault here, clearly Forest River's, if anyone. The dealer is there to sell the coach and hopefully support the customer, and repair the coach as needed. The coach can't be disassembled & re-engineered in prep.
Just out of curiosity, is that 10 gauge wire? If so, it is rated for 30 amp, which is basically what the trailer's electrical system is rated for. The only thing I don't like is that the wire nut wasn't on there very well probably because they didn't strip the wires enough, are trying to join too many together, or didn't use a big enough wire nut.
I do have a strong belief that the Amish folks don't have much place in electrical wiring or plumbing, based on what I've seen. Cabinetry, though, is great.
PumaPro is offline   Reply With Quote
Old 05-02-2010, 09:22 PM   #10
backin15's Avatar
Thanks for the heads up. I checked mine and like KyDan my wires all connect at a buss bar.
backin15 is offline   Reply With Quote
