Old 10-06-2010, 09:56 PM   #11
DCRC's Avatar
Well doing the math it looks like I am safe by over 200 lbs at GVRW when evenly distributing carrying weight equally over tongue and axles.
GVWR is 7632
TW 623
Dry weight 6056
Weight over axles (DW-TW)= 5433
rated carrying weight 1529
TW + 10% of carring weight = 776
Weight over axles + remainder of carring weight =6809
and my tires are rated for 7040 lbs.
I am sure I am no where near my GVWR and the items (weight) I have added are more towards the tongue of the trailer.
Thanks for help clarifying this for me.
08 Toyota Tundra 5.7
09 Rockwood Windjammer 3001W
DCRC is offline   Reply With Quote
Old 10-07-2010, 04:06 AM   #12
Just make sure you have a spare tire, because if you have a flat you will not be able to tow with three tires especially if you are loaded.
Old 10-07-2010, 08:40 AM   #13
I'm going to look into getting the Kumho tires that are a better load range, a D load range should give you a better sidewall strength, and a higher weight carrying capability. That way, the numbers should be well beyond the comfort zone. Randy
Old 10-07-2010, 05:58 PM   #14
mjones12's Avatar
Yes, check them out and see what you think. I had a Casita camper and got to know lots of others who had them. They came standard with the 14-inch Goodyear Marathons C-rated, and the Casita forum was full of horror stories about the Goodyears failing, probably through no fault of the tires except that people likely overloaded them. I and many others went to the D-rated Kumho's, and everyone I heard from liked them. They are a Korean company, but I heard they were building a plant in Georgia a couple of years ago, but not sure if that actually happened.
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
mjones12 is offline   Reply With Quote
Old 10-07-2010, 07:56 PM   #15
old guys's Avatar
Just a quick question. Does anyone know if the D-range Khumo tires are st tires or car/light truck tires, as we will be replacing our C- range 14 inch tires with D's; when they wear out. Old guys
Best loved friend ever!!! (greatly missed)
old guys is offline   Reply With Quote
