09-10-2010, 11:04 AM
Proud Member
Freezer is cold, fridge is doing nothing.
My Dometic 2652 seems to be acting up. This is a new problem as it worked fine on the previous trip 3 weeks ago.
After being on 12 hours, the freezer is quite cold, 34 degrees F and falling. However the refrigerator is doing nothing. The fins in the back feel about room temperature and it is 63 degrees F inside the refrigerator. The outdoor temperature is in the 70s today.
Here is what I have tried:
- Camper is level
- Both 120V and Propane mode
- Installed internal cooling fans. (Neat invention by the way)
- Checked the fuses on the control board: good.
- One recent thread mentioned a damper between The fridge and freezer. I have looked and I see nothing like that on my model.
- I have tried it with the temp sensor clipped on and off of the fins.
- I just placed a 1 gallon jug of ice in the fridge, so I haven't seen what that will do for the problem
My next step will be to call for service, but I hit the road in about 6 hours, so I don't suspect I will get much help from a service tech until we return next week.
Does anyone on this forum have any other ideas that we can try?
Jim P.
2008 Surveyor SV-291
2003 Ford 4x4 Expedition
Reese SC WD System 800/10,000 lbs
1976 Cessna 177RG
Wife, son, twin daughters, and mother
09-10-2010, 11:11 AM
We were having problems with ours just before a long trip in May. Ended up using coolers and ice for the trip. When we took it in to the Domettic service center they did some tests and replaced a Thermister on the back side. I can't tell you if this is the issue but you might make a call and ask how much for one. If not too much it may be worth it to swap a new one in just to see.
On another note I see you have a Cardinal. We used to own a Piper Arrow and did a lot of flying back when I was in high school (boy that was a long time ago). If you ever get over to the Northern Idaho, Oregon, Washington area I work for Seattle Center as a radar controller, shoot me an "N" number an perhaps we will talk on air.
09-10-2010, 11:15 AM
Not sure if this wil help but on our frig there is an on/off switch. When you open the door to the frig look at the top kind of under the freezer door. This may have been shut off by accident. Good luck.
09-10-2010, 11:20 AM
It can take 24 hours for the frig to cool properly, so it's possible that you haven't let it run long enough. Openning and closing the door to check on it will make it take longer as well.
Hope this helps.
Gary & Trish
2011 LaCrosse 303 RKS Touring Edition : 2007 Flagstaff 206ST MAC Series
2010 F-250 XLT : FX4 : CC : SB : 6.8L V-10 : 4/10 Gears
2012 Nights Camped - 5
09-10-2010, 11:53 AM
Proud Member
Here we are an hour later, and it has now kicked into gear. The refrigerator box is now 47 F and falling. The fins are cold now too. I think grhodes50 called it, patience. Another factor may have been the switching to propane, but I am not sure.
TimeToTow, I know the switch you are referring to, but it is to turn heat tape that reduces the external condensation. It is off on my unit because we live in an arid climate where condensation is seldom an issue. That, and we often dry camp so the heat tape only drains my battery even faster.
NWJeeper, nice to know. I will touch base via email.
Jim P.
1976 Cessna 177RG
09-10-2010, 12:01 PM
Happy to hear that there was no problem!!
2008 Berkshire 390bh DP
09-10-2010, 03:48 PM
Location: Jacksonville Florida - Home of the Jaguars !!!!
The refrigerators in campers are not going to operate as well as a home unit. Also, most of them don't have a cooling fan- they are simply an icebox. We usually start ours on the morning we are going camping, that way it's good and cold before packing it up with food and leaving. You can also run it on gas while traveling, but watch out at gas stations, tunnels, and ferries. Randy
 '08 V-lite Flagstaff 30WRLS
'06 Ram 1500 QC hemi  Reese dual cam sway control,
K&N series 77 intake, Hellwig pro series helper spgs.
'04 Durango Limited Hemi, '72 Mach One 351 cj
09-10-2010, 03:51 PM
We usually put a couple of 2 liter soft drink bottles of frozen water in there when we turn it on. It seems to cool down quite a bit faster.
Terry and Joan and our empty nest
2008 Silverado Crew Cab 5.3liter 3.73
"The Cottage" (2010 Surveyor Sport 189)
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 662 |
| 139 members and 523 guests |
| 1l243, 5Galvs, adp1326, Alisa06, B47, bagged123, BeagleIL, Bearcat55, BlakeB, bob213, bob34787, boubou, brady, Buckeyecmpr, buckeyefan, Buffalohunter, Cafjackracing, cat1956, CCrane2299, cfsoistman, chof16, clarktod, ColoradoGreg, Cowracer, cstover, cyclepuck, danielpburke, danred, dapersico, DAREK.NIEUWSMA, Darren K, davidjb, dfrauhiger, donn, doosterhouse, Douginbc, dustman_stx, dville_v-lite, dwmangold, EastlakeRoo, ecrissman, emljr, Falcon35, Filthy Beast, Fire Instructor, Foneguy, FR28footer, gamller36, Gary0848, gator14, hairmommy, HemiCab, hokiecampers, Iggy, iluvlcy, irish01, Italia2012, Itsthetwoofus, jamesroadking, Janet H, jar3316, jaydub3000, jerbear62, justinph, jwuertz, kegoneill, ken0042, KKapa, klucas, kybaja, KyDan, lbrjet, ldmcmahan, LFugate, lmcleister, lochsa, Lonewolfcry, lowbubba, Malco, manvel, Mark S, Medic44, mhartzel, Mickey1, MIKE44460, milw156, MN128S, Mnflyboy, mrores, mtnguy, nailit, ncgrl1, OffPavement, pandkm, papap, PaulK, pchrcane65, Phil1, photog, pmsherman, punkaccountant, racedaymechanic, redfox217, Retired63, rickthelen, rkswyo, Rob H, Rogue69, SabreSam, sail2liv, Savage, scout800, SDENN4281, shane1234, shineysideup, silly2635, SimchaSabre, skeeterbait8, skennedy, Stedman1, stevem4134, T.Kott, TacBear, tbritt, tedstr, texashatter, tlc, tmmar, travyp, Triguy, Vernk, Vette4trcr, vlite2011, wagon52, Warrior, whj77372, william.migues, wolfpack21643, Zadnichek |
| Most users ever online was 944, 03-04-2012 at 01:27 PM. |
