Old 07-28-2011, 04:21 PM   #11
The freon type should be listed somewhere on the A/C unit. Look for the ID tag.
03 Chevrolet Silverado 1500, 5.3 V8, 3.73
06 Rockwood Roo 23SS
Equalizer Hitch
dlhoppe is offline   Reply With Quote
Old 07-28-2011, 08:08 PM   #12
Before I would have a professional have at it, you can make some easy inspections yourself. First and I'm sure you have, inspect your filter material in the return air. Could be clogged or if torn/missing, the evaporator(cold coil) could be dirty not letting good airflow through. Next, I'd check the rooftop condenser coil. Could have bent fins that need straightened(from hail damage). This would affect your performance out of your A/C. If you're in the extreme heat like we are in the midwest, get a fan to supplement & keep the air moving near the floor. When it gets over 95 degrees, a single A/C in a trailer can't keep up when your parked in the open sun. Go swimming! Good luck.
2006 Rockwood 8272S
2005 Chevrolet Silverado
John & Pandra
Battlefield, Missouri
F.R.O.G. Member
1st International F.R.O.G. Rally Branson Missouri
JohnandPandra is offline   Reply With Quote
Old 07-28-2011, 08:27 PM   #13
onetonford's Avatar
It is possibly one of the newer freons possibly a 401a and the only way it can be recharged is by a Refrigeration tech. They do not use tap valves on any new freon types they have to use a temp type valve and remove all freon first then they weld on a temp scharader type valve check for and repair leaks. Then they fill unit to the amount listed on unit then they pinch off tube before valve cut off and weld the end of tube closed.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
