01-16-2020, 10:01 PM
Fresh water connector with vent?
I have been searching for a 90 degree connector for the freshwater fill that has a vent on it. The attached pictures show a regular brass elbow with a vent like I'm looking for and then the standard 90 degree connector you can buy anywhere. I can make what I want using the shown elbow and then some other brass fittings cobbled to it but - it will weigh more than I'd like.
So, anybody seen such a thing out there?
I just want to be outside!!!
'17 Salem Cruise Lite 210RBXL
'11 F150 5.0
Only one shedding mutt now RIP Yoshi
01-16-2020, 10:38 PM
What exactly are you trying to solve? If you want to bleed when connected to city water, opening a faucet will accomplish the same.
Tundra 2017 CrewMax retired for a RAM Laramie 2500
FR 2017 T2460 EVO
Andersen sway control
01-17-2020, 09:52 AM
Yes, bleeding off the air in the hose is the idea. I usually forget to charge the hose before connecting so I get all the "burps" when I turn on a faucet afterwards. I figure if the bleed valve is right there on the connection, it will jog my feeble memory...
'11 F150 5.0
01-17-2020, 09:57 AM
you'll still have air in the lines
01-17-2020, 10:07 AM
you need a hobby.
01-17-2020, 10:12 AM
How about a hose tee and a hose valve?
Gotta go campin!
01-17-2020, 10:36 AM
Thanks Bama Rambler, that might be a good alternative - certainly a lighter one.
Cavie - making "stuff" is my hobby (I don't have a Mouse Trap game anymore so this is what I do)!
'11 F150 5.0
01-17-2020, 02:58 PM
No, not a tee
A one-piece solution is to use a "Siamese", also called a Y-splitter. The 60-degree angle is close enough to 90 for the female inlet. The lower male outlet connects horizontally to the trailer fresh water inlet. The upper male outlet points straight up at the sky and is your vent.
We've done it this way for years.
Larry
01-17-2020, 03:30 PM
geezer with gadgets
We use one of these:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Works great for bleeding the line and I have a hose connection for any other need that might arise.
Sent from my Atari 2600
2011 Sunseeker 3170ds "Ladybug"
2017 Jeep Grand Cherokee TOAD
Days camped 2015: 37; 2016: 66; 2017: 86 2018: 57 2019: 30
01-17-2020, 03:48 PM
Originally Posted by 757Dave
Well now that's just excellent!
I'll have a couple of those as soon as Amazon can get them here!
Gotta go campin!
01-17-2020, 07:45 PM
X2.
2016 Salem 27RKSS
01-17-2020, 09:49 PM
Originally Posted by nayther View Post
you'll still have air in the lines - Yes, but not a whole hose full!
Larry NR - I like your suggestion. I already use a Y connector at the CG's connection but using one at the trailer seems easy enough!
'11 F150 5.0
01-17-2020, 09:57 PM
One more thing...
It's also a convenient place to hook up the pressure washer when washing the trailer.
Larry NC
Larry
01-18-2020, 01:12 AM
Do you 'flush' the fresh water hose before you use it? That's always a good idea.
Putting a shutoff valve on the end of the fwh should solve some of the problem. Flush the hose, turn off the shutoff valve, connect to the elbow on the rig and turning on the shutoff valve should take out most of the air. Then all you'll have is the air in the rigs lines.
2015 Dynamax REV 24TB class C
01-18-2020, 01:19 PM
OK, I think I found my winner here. Thanks!
'11 F150 5.0
01-19-2020, 12:33 PM
AKA: 'tiredTeacher
Having a bleed at the trailer would help with those cold nights when you have to empty your hose overnight.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
01-19-2020, 07:22 PM
2016 Rockwood Windjammer 3001W
2016 F150 SCREW 3.5 EB
ProPride 3P 1400
01-19-2020, 07:43 PM
Originally Posted by Oafdawg
Yes, that was mentioned in post # 8.
Days Camped ☼ '19=118 ☼ '20=116 ☼ '21=123 ☼ '22=134 ☼ '23=118☼ '24=64
01-19-2020, 07:46 PM
I always leave the hose loose a little, turn it on than go back and tighten it up after all the air has bled out.
