Old 08-24-2011, 05:51 PM   #21
Herk7769's Avatar
Originally Posted by f1100turbo View Post
Yes jerk I believe he has the front pads the same height regardless of ground unevenness.
I found dropping the feet via the pins and then as you said raise them two inches evenly works well.
God, I hope you meant "Herk!"
HAM CALLSIGN - KC3FFW
Old 08-24-2011, 05:53 PM   #22
Herk7769's Avatar
Originally Posted by Rugged Brown View Post
I use different pin holes depending on the terrain, however, this could still result in at least 2 " difference because of the distant between the pin holes. It's an incremental adjustment rather than continuous. Am I just splitting hairs here now. In any event, the difference during my last setup threw my camper out of side to side level.
I found that you can "lift" the outer sleeve a bit to mate with the optimum hole. You shoud be able to get the legs within an inch.
Old 08-24-2011, 05:57 PM   #23
TURBS's Avatar
omg I am so sorry herk ! sorry did not proof read
Old 08-24-2011, 06:26 PM   #24
Herk7769's Avatar
Been caught like that myself. I do spell check but no spell checker in the world will catch the wrong, though correctly spelled, word!
Old 08-24-2011, 06:35 PM   #25
RV Newbie
buzzards27's Avatar
Herk, with this phone's autocorrect I make the same kind of error every day. You never know what this thing will settle on. Every time I type "like" it uses "Luke"... go figure.
2005 FR Lexington 210 6.0L 8500 miles
2007 2500 Silverado Ext. Cab, 6.5' bed 5.7L
2010 Ford Fusion Hybrid
1963 Ford 861 5 speed with loader
1958 Ford 800 Select-O-Speed (parts tractor)
buzzards27 is offline   Reply With Quote
Old 08-24-2011, 06:49 PM   #26
onetonford's Avatar
You can buy a screw leg for one side and adjust as needed. I just take a few peices of 1/2" plywood just to get it close. I also have used a longer piece of 2 x 6 that I put under and then using a piece of 2 x 4 across at one end and slide it as a wedge so that it takes up the slack.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 08-24-2011, 07:11 PM   #27
Rugged Brown's Avatar
I like the 1/2" plywood idea. I think that will do the trick. Thanks everyone for, once again, solving a fellow RVers woes.
Terry/Bernadette
Lily the Yorkie
2015 Dodge Ram Sport 1500
2015 Crossroads Zinger ZT28BH
Rugged Brown is offline   Reply With Quote
