Old 08-23-2011, 12:50 PM   #1
Rugged Brown's Avatar
Front levelling jacks on Fifth Wheel
Are the 2 front levelling jacks on a fifth wheel self levelling. By this I mean, can one lift the unit independant of the other or will it wait until both jacks have force applied. I think the one on street side of my flagstaff 8528CKWS will lift camper even though the other one is not yet firmly planted on blocks. Please enlighten me.
Terry/Bernadette
Lily the Yorkie
2015 Dodge Ram Sport 1500
2015 Crossroads Zinger ZT28BH
Rugged Brown is offline   Reply With Quote
Old 08-23-2011, 02:12 PM   #2
TURBS's Avatar
They work in tandem.
They lift at the same rate
Old 08-23-2011, 03:01 PM   #3
If they are on uneven surfaces, will one lift or wait for the other to catch up.
Terry/Bernadette
Lily the Yorkie
Old 08-23-2011, 03:05 PM   #4
TURBS's Avatar
What brand of jacks?
Old 08-23-2011, 03:09 PM   #5
TURBS's Avatar
Mine Are lippert the drive motor (curb) side bolts to the right gear housing jack then there's a solid shaft to right side bolted to gear housing.
Old 08-23-2011, 03:24 PM   #6
As you can see from the rear jacks, they are at different levels yet have the same tension.
When I lowered the front jacks, the street side jack engaged before the other one and started to raise the camper before the second jack became engaged at all. I think that is wrong. I dostand to be corrected.
Name:	rear jacks.jpg
ID:	7575   Click image for larger version
Terry/Bernadette
Lily the Yorkie
Old 08-23-2011, 03:30 PM   #7
TURBS's Avatar
Yes the rears act independent from each other.
Old 08-23-2011, 03:32 PM   #8
TURBS's Avatar
How much difference in the fronts?
i just looked at mine and theres no way for them to be out of sync .... but theres plenty of play within the cross shaft and other gear housing for it to appear that ones lifting shortly before the other starts since the curb side gear housing is direct drive to the motor.
then you would have one gear catch up on curb side then the cross shaft play then the passenger side gear to catch up.
sound logical ?
Old 08-23-2011, 03:52 PM   #9
Sounds logical, but if I have my camper levelled side to side when parking and then disconnect the truck, and lower the front jacks, if one engages before the other, it puts my trailer out of side level. I can't remember this happening before.
Terry/Bernadette
Lily the Yorkie
Old 08-23-2011, 03:55 PM   #10
TURBS's Avatar
hmmmmm . look at your cross shaft and see if the shear bolt is twisting as you raise or lower ?
