Old 09-16-2011, 09:37 AM   #1
Fuel station pump prime problems
I have a 19' Wolf Pack that has a atv fuel station. I have added 5 gallons of fuel and the pump operates along with all switches/timers. I can't get the gas pump primed to get fuel delivery through the nozzle. The gear pump is supposed to be self priming according to the info I have.
Does anyone know any tricks to get the system primed? Would appreciate any help.
vapor1000 is offline   Reply With Quote
Old 09-16-2011, 10:53 AM   #2
TURBS's Avatar
Is 5 gallon enough to get it primed?
Just saying
Old 09-16-2011, 11:08 AM   #3
I'm not sure if 5 gallons is enough to prime the system or not. I was hoping someone out there had done this before I put more fuel in the tank. The pump is blowing air through the fill nozzle, so the pump is working. It's just not primed.
Thanks for any help you guys can provide.
Old 09-16-2011, 11:56 AM   #4
Bill_C's Avatar
I would say if the nozzle is blowing air then the pump is sucking air and the pump is working. I think f1100turbo is on the right track. Before thinking anything is wrong, add another 5 gallons of gas.
DRINK COFFEE--do stupid things faster and with more energy ! Rockwood 5th wheel, Signature Untralite, 8244S
Tow Vehicle: Ram 3500 6.4 litre Hemi.
Bill_C is offline   Reply With Quote
Old 09-16-2011, 12:41 PM   #5
OK, thanks for your input. I'll try another five gallons and let everyone knows if it works.
The tank holds 30 gallons of fuel. I sure hope I don't need to keep 10 gallons in the tank just to get it primed!!
Old 09-16-2011, 12:59 PM   #6
Bill_C's Avatar
5 gallons may be the same as empty. Looking forward to your findings.
Old 09-17-2011, 12:35 PM   #7
Well, the pump finally primed. I would say it took around 8 gallons to achieve prime. Sure glad I tried it because some really nasty gas came out of this never been used fuel station!! I pumped a gallon or so into a clear jug until it cleaned up. I sure would not want that first stuff in my Polaris RZR ATV!!
