Old 06-05-2016, 01:08 PM   #11
Forester Fred's Avatar
Location: On the road between New Hampshire and Florida
All I use on my Chevy Express/Forester, Toyota FJ Cruiser, GMC Sierra pickup and Kubota diesel tractor is full synthetic oil. (diesel oil for the tractor)
I have never had any issues with blowby, burning or consumption on any of the vehicles and the GMC has 182k miles on it.
In November I changed the oil in my motorhome to full synthetic (Mobil 1) from the factory oil. I drove my motorhome from New England to Florida in December then out to California in March and back to Florida - where I changed the oil and it never burned a drop. I got out as much as I put in.
2015 Forester 2301 - Chevy
Skip & Deb - Bridgewater, NH & Delray Beach, FL
Forester Fred is offline   Reply With Quote
Old 06-05-2016, 02:04 PM   #12
oldsmasma's Avatar
Yup x12. Luckily for us our DS sells synthetics and the parental discount makes it as cheap as water. Use it in all our motors without any issues.
Phil, Heather & Olaf the Boxer
Ontario Canada
Lexington 283GTS
oldsmasma is online now   Reply With Quote
Old 06-05-2016, 02:19 PM   #13
camaraderie's Avatar
Well I've been using full syn for 2 years and across the country & back and have never been down even a quart.
________
Cam
2015 Georgetown 280DS
2014 Vespa LX150 2014 StellaAuto 125
camaraderie is offline   Reply With Quote
Old 06-05-2016, 02:44 PM   #14
sfsgm's Avatar
Originally Posted by lucky55616 View Post
I have a Sunseeker 3010DS on a 2014 Ford E450 chassis with 2,700 miles on the odometer. On my last oil change I had 5W-20 full synthetic put in instead of the semi-synthetic blend. When I brought the motorhome into a Ford dealer because the check engine light was on, I mentioned to the service manager that I recently had the oil changed and went with full synthetic. He said I should not have done that because the 6.8 V10 will burn a quart of full synthetic every 1,000 miles as blowby and that once you put full synthetic in the engine you can never go back to the semi synthetic blend. I have never heard of that before and the Ford manual recommends either the semi synthetic blend or full synthetic. Has anyone else started using full synthetic and did you have any problems with the engine after you started using it ?
No, you shouldn't have a quart of blowby.
As for going back to regular motor oil, I've heard this before on radio auto "repair" shows and it was by people that really, REALLY should know.
As for blended motor oil: The blend is whatever the manufacturer wants to make it. Some reportedly use as little as 5% of synthetic oil and some use up to 20%. I haven't heard of more than that but there could be brands that do. I use full synthetic oil in my cars. I don't use it in my truck as putting 14 quarts get pretty expensive but I change that oil a LOT sooner.
2016 Nike Take Down Wrestling Shoes
38 ft square Dollamaur High School Wrestling Mat
sfsgm is offline   Reply With Quote
Old 06-05-2016, 03:00 PM   #15
I have used AMSOIL after Manufacturer Warrantee runs out. Great product and you don't have to change the Engine Oil as often.
David L Horton
2016 Georgetown 328
dphorton is offline   Reply With Quote
Old 06-06-2016, 06:35 PM   #16
Iwannacamp's Avatar
Originally Posted by RamblerGuy View Post
I agree with the others. We just completed a 5,500 mile trip in our 2011 Sunseeker with the Ford V10. It used less than one pint of oil. I have always used NAPA 5W20 full synthetic (claimed to be manufactured by Valveoline).
Is/or was Ashland oil which is/was Valvoline oil...as per rep. Exact same oil. Have seen wrong labels on bottles. I have been gone 10 years. Could have changed.
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Old 06-06-2016, 07:07 PM   #17
No reason to wait
Federal law prohibits voiding of a warranty simply because you used a product like Amsoil. As long as you comply with the maintenance schedule and viscosity recommendations, there is no reason to not use it.
I switch to Amsoil at the first oil change. Many vehicles come with full synthetic from the factory - so the whole "it needs to be broken in before you use synthetic" statement does not apply to modern engines.
KatanaPilot is offline   Reply With Quote
Old 06-06-2016, 07:12 PM   #18
I am a service manager at a Ford dealership. You can use full synthetic without any worry. Also you can switch back and forth as often as you want. Blow by would be there regardless of the oil you use. If you are not using oil now, you won't with full synthetic. Most manufacturers cover their ***** by saying vehicles can use up to a quart of oil in between oil changes. BS. I've never owned a vehicle that was properly maintain ed that used oil.
2015 Silverado 1500
2016 Keystone Passport 3350BH
MarcS is offline   Reply With Quote
Old 06-09-2016, 03:00 PM   #19
I am the OP. Thank you everyone for all your comments on this topic !
lucky55616 is offline   Reply With Quote
