Originally Posted by clk623
I'm having same issue after replacing thermostat with a Honeywell. Will a Honeywell not work with A/C and furnace fans ? Honeywell doesn't have same settings as the Dometic.
Dometics work differently than other units; they are negatively switched, not positively switched, if I understand them correctly. (In other words, the "switch" that turns on the AC is "after" the AC, not before it, in current flow, or put it another way: Positive switching is +12VDC from battery to switch, to AC, to ground, versus Negative switching is +12VDC from battery to AC, to switch, to ground.) Causes problems with standard t-stats.
If you had an analog Dometic t-stat, your best bet is to replace it with a plug-and-play digital Dometic.
Maybe someone who's figured out how to do it with a standard t-stat will chime in.
