Old 04-24-2016, 07:32 PM   #1
VizJedi's Avatar
Furnace and A/C running at the same time.
I have a 2016 Coachmen Chaparral I bought in January. It's my 4th trailer.
Just returned from our 4th camping trip this year. We used the furnace all the trips. This weekend when I put the thermostat (Dometic digital) on "Heat", it turned on the furnace AND the A/C. I had to throw the breaker for the A/C to get just the furnace to run. During the day, it got hot so I switched the thermostat to "Cool" and the A/C worked fine. (after I flipped the breaker back on)
Pretty sure it's the thermostat, but I'm hoping this is a common issue with an easy fix. My dealer is 2 1/2 hours away.
j
2016 Coachmen Chaparral 390QSMB
2011 F350- CC, DRW, LB, PSD
2016 nights camped: 40
2017 nights camped: 16
2017 nights reserved: 30
VizJedi is offline   Reply With Quote
Old 04-24-2016, 07:37 PM   #2
Head Rambler
If the fan on the t-stat is set to Lo or Hi it will run whenever the furnace runs. Crazy, I know, but that's how they work. Set the fan to Auto and it won't run when the furnace is on.
Gotta go campin!
Old 04-24-2016, 07:43 PM   #3
VizJedi's Avatar
A Google search after I posted turned up the same thing and a post on here from 2013 saying the same. Here
Apparently DW said she was "playing" with it the day before. Now I have to figure out how to put it back on Auto since it doesn't make it very obvious.
j
Old 04-24-2016, 07:50 PM   #4
Mr. Dan's Avatar
Set the thermostat mode to FAN then use + or - to cycle through HI, LO, AU
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 29; booked = 12
Old 04-25-2016, 03:31 PM   #5
dicky1243's Avatar
j
The easy fix is to make sure the fan is on Auto that sollves the problem
2006 Gmc
2016 Forestriver Sierra 376 BHOK
Full Timers
Dick,
dicky1243 is offline   Reply With Quote
Old 04-25-2016, 03:54 PM   #6
Yup. I was dying trying to figure this one out. As others have said, set the fan to auto. Problem solved.
TV: 2016 Ram 3500 4x4 mega cab w/6.7l Cummins
Trailer: 2013 Palomino Puma 27SBU
bitNine is offline   Reply With Quote
Old 04-26-2016, 07:59 AM   #7
Team Bleu
We turn the fan on Auto and then I turn the AC to 55 and heat up to 70 when using in the winter, then I reverse it heat down to 55 and AC up to 70. Crazy how those dials works
DBsRedVett is offline   Reply With Quote
Old 04-26-2016, 07:42 PM   #8
nice tip to remember, wife set ours to C and she read the book and -+ @ same time back to F
pbandrb is offline   Reply With Quote
Old 04-26-2016, 07:59 PM   #9
Flybob's Avatar
Just in case.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 04-27-2016, 08:17 PM   #10
VizJedi's Avatar
Originally Posted by Flybob View Post
Just in case.
Thanks FlyBob,
I found one and read through it, but didn't save the pdf. I have this one now. It made sense when I read it, but 3 weeks from now when we are heading out again... What did they say about the first thing you lose?
j
furnace
