Old 09-14-2014, 04:26 AM   #1
BuckeyeChuck's Avatar
Furnace blower
My furnace blower will not turn on. I put the thermostat (Dometic ) in the furnace mode set the temperature to the desired degrees (72) and nothing happens. The fan is set on auto. The A/C mode is set to 85 degrees. Any ideas?
2012 F250 Super Duty
2013 Sabre 33CKTS
BuckeyeChuck is offline   Reply With Quote
Old 09-14-2014, 05:04 AM   #2
Ford Idaho's Avatar
Do the stove burners light?
If not, turn off the gas at the tank and then turn it back on real slow.
Now try and light the stove burners.
If you have not used the trailer recently check the voltage of the batteries, if they are low then charge them and try again.
Old 09-14-2014, 06:30 AM   #3
Stove works fine. Battery is fully charged. We are on a seasonal site snd sre plugged into 50 amp shore power.
2013 Sabre 33CKTS
Old 09-14-2014, 06:55 AM   #4
fonzie's Avatar
Check the 12 v fuse in your distribution panel if not blow.
Fonzie
Old 09-14-2014, 06:58 AM   #5
Ford Idaho's Avatar
Ok, do you have vent screens to keep spiders and mud daubers out?
If not then you need to pull off the outside cover and check for wasp nests and spider webs in the vent.
Old 09-14-2014, 12:37 PM   #6
Checked the fuse....it's ok. Next I'll check pull the cover and check the vent. I did have wasps in the fridge vent locatrd near by.
2013 Sabre 33CKTS
Old 09-14-2014, 01:15 PM   #7
Nope all good there. Thanks
2013 Sabre 33CKTS
Old 09-14-2014, 07:59 PM   #8
I'm thinking its time for a call to the service department.
2013 Sabre 33CKTS
Old 09-18-2014, 07:33 AM   #9
UPDATE: American RV service department sent out a tech. two days after I called them (very fast). The problem turned out to be a bad circut board. All is good now. Thank you AMERICAN RV. Once again you gave me fast, friendly, professional service.
2013 Sabre 33CKTS
furnace
