Old 05-23-2018, 02:24 PM   #1
bpa098's Avatar
Furnace issue/thermostat change
Ok I've read a bunch here and other places. So correct me if I'm wrong. Due to some issues with my furnace (runs fine for a few hours then quits) I am going to try changing my thermostat to see if it helps.
So if I've read things right, changing the digital domestic thermostat to a basic home thermostat running on batteries should be easy and a stab at fixing my problem.
It's a 2015 palomino hybrid. Thermo runs furnace and a/c. If you need more details let me know. And yes it was to a dealer before and of course it ran fine while it was there. Once it stops working I turn off the thermostat, wait a bit and turn it back on. It will fire up (it will lite and blow hot air) then 5 minutes layer it dies (assuming gas is killed and fan blows a few more mins). Almost like a sensor says it's not lit or it's already up to temp. Once it dies it never fires back up.
Works fine when it's warmer out. But when it's cold and we want it, that's when it acts up. Each time we camp in colder weather we have full hook ups. But does the same on hook up or battery
bpa098 is offline   Reply With Quote
Old 05-23-2018, 02:31 PM   #2
Kaadk's Avatar
Based on your description of your problem, I'd be looking more at the Furnace. Either control board or the flame sensor. It sounds like what you said, that it's not detecting that it's lit and shutting down. Those brains are all in the furnace.
Kaadk is online now   Reply With Quote
Old 05-23-2018, 02:47 PM   #3
bpa098's Avatar
Problem is getting at the furnace without tearing out a cabinet built around it
Old 05-23-2018, 02:51 PM   #4
bpa098's Avatar
Maybe changing the thermostat is a waste of time?
Old 05-23-2018, 02:57 PM   #5
Kaadk's Avatar
I'm not familiar with your unit, but I don't typically see the need to completely dismantle a cabinet. They usually expect these things need servicing so provide some kind of access panel. Maybe a couple of pictures of the unit might help narrow it down.
Old 05-23-2018, 03:30 PM   #6
bikendan's Avatar
That's odd. Every RV I've ever seen, had access to the furnace, both inside and outside.
Equalizer WDH
Old 05-23-2018, 04:06 PM   #7
Head Rambler
The issue is that the thermostat that you show uses digital communications and it isn't an easy task to convert it to an analog unit. You not only have to replace the thermostat, but you have to replace the control box in the A/C and pull new wire from the T-stat to the control box.
If you really think the thermostat is the problem, I'd buy a really cheap thermostat and temporarily hook it up and see if it does the same thing.
Gotta go campin!
Old 05-23-2018, 04:58 PM   #8
cavie's Avatar
Mine is only on the inside through the cabinet. Outside only have the vent.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
cavie is online now   Reply With Quote
Old 05-23-2018, 05:02 PM   #9
bikendan's Avatar
Can't you take the vent cover off?
I can on mine.
Equalizer WDH
Old 05-23-2018, 05:05 PM   #10
bpa098's Avatar
I'll get pics when I get home. Maybe I can get at what I need to. I'll have to reach about the board and sensor
furnace, thermostat
