Old 04-12-2016, 01:34 PM   #91
heater where is
Originally Posted by bob caldwell View Post
Remove unit from RV and remove from housing to gain access to fans. Shut propane bottles off, light stove to empty lines....
05 gtwn 375 ts
where is the darn thing ?? in baY or in a panel or ?
first attempt to fix my self thank you glenn
glenn56h is offline   Reply With Quote
Old 04-12-2016, 03:50 PM   #92
Left Coast
Go outside and look for the exhaust/intake vent ( 2 round holes, about 2" in dia, one above the other........then you'll have to gage about where your at on the inside.....will be behind a removable panel
Old 04-21-2016, 11:33 PM   #93
It appears you have the t-stat as cold as it will go. Slide the lever all the way to the right to test. Don't forget to reset to desired temp when done. As mentioned you can jumper at t-stat or if I recall there are 2 light gauge thermostat wires at the heater that can be jumper'd to test. I think they were blue.
mfMcFroggierPod is offline   Reply With Quote
furnace
