Old 04-07-2016, 12:14 PM   #21
WClick image for larger version
Name:	ImageUploadedByForest River Forums1460049196.302667.jpg
ID:	104173Click image for larger version
Name:	ImageUploadedByForest River Forums1460049221.361044.jpg
Cedricshelby is offline   Reply With Quote
Old 04-07-2016, 12:14 PM   #22
I'm plugged into shore power
Old 04-07-2016, 12:14 PM   #23
KyDan's Avatar
As others have suggested.
Pull out the furnace fuse.
Wait a few seconds-
Replace fuse.
Turn thermostat to heat.
Some furnaces have an off on switch behind the furnace front panel.
YOu can remove the front panel and flip the switch off and on but briefly
removing the fuse will do the same thing.
Good luck!
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 04-07-2016, 12:17 PM   #24
Thanks -
Will look for the furnace outside
Name:	ImageUploadedByForest River Forums1460049437.657103.jpg
Old 04-07-2016, 12:24 PM   #25
Flybob's Avatar
Your thermostat has an "off position" Move the lever to the far left until you fill it snap open the switch. Give it 3-4 minutes and try again. The blower should come on and shortly there after the furnace should light.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 04-07-2016, 12:27 PM   #26
Left Coast
For a cheap quick way of checking for 12 volts thru a fuse, a 12 volt test light is what I'd use....connect the alligator clip to the batt. neg on the panel in your pic, and use probe to see if current is really passing thru fuse....on the face of fuse, there is a little metal area show'n, on each side on face, that you can probe...if light lights, fuse is good
Old 04-07-2016, 12:30 PM   #27
Head Rambler
Sometimes fuses will be blown but look like they're fine. I'd suggest swapping the furnace fuse and another fuse just to make sure. Then if the furnace starts working and something doesn't you'll know that it's the fuse.
Gotta go campin!
Old 04-07-2016, 12:35 PM   #28
Left Coast
Will only be an intake/ exhaust vent outside....the panel covers the furnace on the inside, and has slits in it for air, and is screwed into place....
Old 04-07-2016, 12:39 PM   #29
I guest that was not possible :-(
Old 04-07-2016, 12:40 PM   #30
Thanks - let me try some of this
furnace
