Old 04-07-2016, 07:14 PM   #41
bob dirt's Avatar
did you jump out the red and white wire like suggested earlier?
...with a paper clip, piece of wire or something similar
2016 Forester 2401WS MBS
Life is short...eat the cookie
bob dirt is offline   Reply With Quote
Old 04-07-2016, 07:14 PM   #42
Flybob's Avatar
If you are going to diagnose this yourself, go to Walmart, Harbor Freight or radio Shack and purchase an inexpensive auto ranging meter. a Neon 120V test light is of no use when diagnosing the 12V system in an RV.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 04-07-2016, 07:22 PM   #43
Originally Posted by Cedricshelby View Post
From your picture, looks like it is in the Off position and the heat anticipator is not set correctly.
Old 04-07-2016, 07:32 PM   #44
Left Coast
Are you still here?
Old 04-08-2016, 03:47 AM   #45
Who Dares, Wins
doc73's Avatar
Sometimes trying to fix things ourselves to save a few bucks ends up costing more because more gets broken.
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 04-08-2016, 07:27 AM   #46
wmtire's Avatar
Originally Posted by hbillsmith View Post
Have you possibly, recently remove and filled your propane tanks? If so you may have air in the furnace lines. This happened to me and the solution was in the owners guide for my furnace.
I'm with hbillsmith here, are you sure you even have propane, and the cylinders are turned on (open)? This is the more common root reason for your furnace not working (it works off propane), and is the easiest thing to check for before you start going too far into the 12 volt reasonings.
The furnace is a huge propane user, and you may be just out of propane, or real low.
Have you tried lighting your stove?
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 04-08-2016, 07:47 AM   #47
Kaadk's Avatar
In post #1 they stated the propane stove works fine.
Given the information to date, since trying to reset the lockout didn't work, and based on the other posts, I agree with BandB that it's probably time to call a mobile tech.
Even though it's costly, it's still better to call someone then it is to risk an incident trying to troubleshoot something that deals with electricity, propane and fire.
The surest way to lose is to play Marco Polo with a ventriloquist.
Old 04-08-2016, 07:47 AM   #48
Pickin' & Campin'
Post # 1 says the propane stove works fine.
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 04-08-2016, 08:13 AM   #49
Left Coast
Thought he said stove was work'n fine
Old 04-08-2016, 10:46 AM   #50
Who Dares, Wins
doc73's Avatar
I know he said that, but not to be stupid, does it? My oven will run for 3 or 4 minutes easy even with the tanks off. So a quick check might not work.
But I cannot remember if he said the fan even tried to fire.. Did anyone else suggest to just change the thermostat out? I think someone had a furnace issue, everyone trouble shooter it to death and it turned out the thermostat was bad..
2015 ChevyHD D-Max
furnace
