04-08-2016, 02:54 PM
#81
Last RV was a 2006 Lexington with same problem. A loose wire on the blower motor under refridge was the culprit. Tight fit to work there, but otherwise an easy repair.
04-08-2016, 04:33 PM
#82
Yes. Need a digital voltmeter for sure. Harbor freight has them for about $20. The furnace works on 12 volts from battery. Need to make sure you have that power to furnace. If the thermostat has a fan switch. Try that to see if blower will come on.
04-08-2016, 04:36 PM
#83
Again - thanks everyone - glad to be a part of the rv family - wife took the RV out of town for the weekend - will be back at it Monday -
04-08-2016, 04:38 PM
#84
PM Sent
B and B
04-08-2016, 04:39 PM
#85
Just my 2 cents for, from the picture you posted in your first post the thermostat is set to OFF. push it up high for heat and low for cool. IMHO
2005 Cedar Creek 30RLBS/TrailAir Hitch/ MORryde 7K IS/Disc Brakes/ PI PT-50 EMS/ RV Flex Armor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42/ Garmin 760RV
40 Gal TransferFlow fuel tank/ TST 507
Amateur Radio W5CI 2019 Days Camping 25
2020 Days Camping 7
04-08-2016, 04:51 PM
#86
Not sure if anyone mentioned it but I had the same problem and it was a loose wire in the air conditioner on the 12 volt side. The furnace and air conditioner are interconnected on some units. I removed the air conditioner filter housing on the inside of the trailer and wiggled the 12 volt wires and the furnace started and have had no problems since.
John and Julie Parish
Lansdowne, Ontario, Canada
2015 Ford F250 Diesel
2009 Cedar Creek 34RLSA
Retired but still working sometimes to pay for toys
04-08-2016, 09:06 PM
#87
For situations like that, especially that shore power is available, i carry two small 120v heaters
04-11-2016, 09:58 AM
#88
05 gtwn 375
Fan does not work made strange noise then stopped
how do I get to the fan in the broom where is access so I can replace fan
04-11-2016, 10:24 AM
#89
Left Coast
Remove unit from RV and remove from housing to gain access to fans. Shut propane bottles off, light stove to empty lines....
04-11-2016, 10:57 AM
#90
Running 2 Ceramic heaters on high will draw approx 25A. That plus the converter current will put you right at your limit. If you turn on any any additional appliances TV, microwave, heated bed, etc, you will trip a breaker if you have a 30A connection. . You can not count on running one of the heaters on the 15/20A outlet in the pedestal as in many parks, there is a 100A breaker up stream protecting 3 30A sites.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
04-12-2016, 01:34 PM
#91
heater where is
05 gtwn 375 ts
where is the darn thing ?? in baY or in a panel or ?
first attempt to fix my self thank you glenn
04-12-2016, 03:50 PM
#92
Left Coast
Go outside and look for the exhaust/intake vent ( 2 round holes, about 2" in dia, one above the other........then you'll have to gage about where your at on the inside.....will be behind a removable panel
04-21-2016, 11:33 PM
#93
It appears you have the t-stat as cold as it will go. Slide the lever all the way to the right to test. Don't forget to reset to desired temp when done. As mentioned you can jumper at t-stat or if I recall there are 2 light gauge thermostat wires at the heater that can be jumper'd to test. I think they were blue.
