Old 04-08-2016, 01:02 PM   #71
B and B's Avatar
I asked him to do that 57 posts ago in post # 11.
I know...maybe it was lost in the noise on the thread! Like AM radio at night and 3 stations on the same channel and all i want o listen too is WSM!!!
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 04-08-2016, 01:04 PM   #72
Cedricshelby is offline   Reply With Quote
Old 04-08-2016, 01:04 PM   #73
Unscrew the red wire and touch it to the little brass piece in the end of the white wire and hold it there and see if it comes on. It might take a few seconds for something to happen. Did you kill all 12 volt power to it for 30 seconds and turn it back on. The unit will lock out if it does not lite.
2016 Flagstaff 23lb
Toddupton is offline   Reply With Quote
Old 04-08-2016, 01:10 PM   #74
Pickin' & Campin'
Originally Posted by Toddupton View Post
Unscrew the red wire and touch it to the little brass piece in the end of the yellow wire and hold it there and see if it comes on. It might take a few seconds for something to happen. Did you kill all 12 volt power to it for 30 seconds and turn it back on. The unit will lock out if it does not lite.
That won't eliminate the thermostat... just the on/off switch.
Unscrew the red wire and touch to the white wire. (lower left)
If the furnace blower starts to run, the thermostat is bad.
If the red wire isn't long enough to pull down and touch the white wire, get a short piece of wire and use as a jumper between those two wires.
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 04-08-2016, 01:29 PM   #75
Pickin' & Campin'
Toddupton... a word of advice... if you are going to edit your posts to completely change information you already posted, you should include an edit line explaining why.
I quoted your original post where you suggested touching the red wire to the YELLOW.
You then edited your post (after my quote) to say to touch to WHITE wire.
For folks trying to follow along, things like this make it awfully confusing.
Old 04-08-2016, 01:39 PM   #76
Sorry I was in the middle of editing my post when I saw yours
2016 Flagstaff 23lb
Old 04-08-2016, 01:52 PM   #77
Pickin' & Campin'
Understandable... thanks.
Old 04-08-2016, 01:55 PM   #78
W5CI's Avatar
Originally Posted by JustB_Rad View Post
Go to walmart and buy yourself a heater.....
x2 I have two elect heaters and never run my furnace, I heat on their dime
Cedar Creek 30RLBS/TrailAir Hitch/ MORryde 7K IS/Disc Brakes/ PI PT-50 EMS/ RV Flex Armor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42/ Garmin 760RV
40 Gal TransferFlow fuel tank/ TST 507
Amateur Radio W5CI 2017 Days Camping 77
2018 Days Camping 3
W5CI is offline   Reply With Quote
Old 04-08-2016, 02:14 PM   #79
Hello Cedric,
This could be a loose wire next to the heater fuse and set screw could just need to be tightened down. You need to remove the cover to the fuse and breaker box to check for loose wires.
I had the same problem with my heater in my 2015 Rockwood 8289ws 5th wheel.
Mine is a Suburban heater too but with a different thermostat which runs the A/C and heater. Neither one would come on. I checked fuses and the circuit breakers all ok. I checked for 13.60 DC volts to the fuse positive block side, ok, good power to the power block bar. This is where all the wires from the appliances are wired in on the long aluminum block bar. On the left are all the white ground wires and on the right are all the colored positive wires coming into the right power block with screws to hold the wires secure in the aluminum block. If you use a volt meter put the neg on the neg bar where all the white wires are going to and put the positive wire to the place where the heater fuse goes in, pull the fuse first to see if your getting 13.60 dc volts there. Go to the wire next to the heater fuse and see if it is loose, if it is tighten down the screw to make better contact. If the heater blower is not coming on first then that could be the problem. We all check the fuses and circuit breakers to see if they have been tripped but we all forget to check for loose wires at the power blocks from vibrations while traveling or not tighten down at the factories or could be a loose wire somewhere else. Some sail switches go bad on heaters too. The blower comes on first then then the gas fires up to heater. If you have access to the heater blower fan see if it spins freely and it is not locked up. Hope its just a loose wire if the fuse and circuit breaker are ok. Some Techs don't tell you to check for loose wires. I carry a portable electric heater as backup just in case heater ever acts up.
Doug-2015-8289ws is offline   Reply With Quote
Old 04-08-2016, 02:35 PM   #80
Flybob's Avatar
Think you/we have pretty much exhausted all the push this, reset that, check this options there are. You are now down to three options.
1. Get a meter and trace wiring to determine if/where the problem is.
2. Call a tech and have then fix it.
3. purchase an electric heater
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
furnace
