Old 04-08-2016, 02:54 PM   #81
Last RV was a 2006 Lexington with same problem. A loose wire on the blower motor under refridge was the culprit. Tight fit to work there, but otherwise an easy repair.
billcoll is offline   Reply With Quote
Old 04-08-2016, 04:33 PM   #82
Yes. Need a digital voltmeter for sure. Harbor freight has them for about $20. The furnace works on 12 volts from battery. Need to make sure you have that power to furnace. If the thermostat has a fan switch. Try that to see if blower will come on.
Harkerr is offline   Reply With Quote
Old 04-08-2016, 04:36 PM   #83
Again - thanks everyone - glad to be a part of the rv family - wife took the RV out of town for the weekend - will be back at it Monday -
Cedricshelby is offline   Reply With Quote
Old 04-08-2016, 04:38 PM   #84
B and B's Avatar
PM Sent
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 04-08-2016, 04:39 PM   #85
W5CI's Avatar
Just my 2 cents for, from the picture you posted in your first post the thermostat is set to OFF. push it up high for heat and low for cool. IMHO
Cedar Creek 30RLBS/TrailAir Hitch/ MORryde 7K IS/Disc Brakes/ PI PT-50 EMS/ RV Flex Armor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42/ Garmin 760RV
40 Gal TransferFlow fuel tank/ TST 507
Amateur Radio W5CI 2017 Days Camping 77
2018 Days Camping 3
W5CI is offline   Reply With Quote
Old 04-08-2016, 04:51 PM   #86
Not sure if anyone mentioned it but I had the same problem and it was a loose wire in the air conditioner on the 12 volt side. The furnace and air conditioner are interconnected on some units. I removed the air conditioner filter housing on the inside of the trailer and wiggled the 12 volt wires and the furnace started and have had no problems since.
John and Julie Parish
Lansdowne, Ontario, Canada
2015 Ford F250 Diesel
2009 Cedar Creek 34RLSA
Retired but still working sometimes to pay for toys
jdp105 is offline   Reply With Quote
Old 04-08-2016, 09:06 PM   #87
For situations like that, especially that shore power is available, i carry two small 120v heaters
Kuba is offline   Reply With Quote
Old 04-11-2016, 09:58 AM   #88
05 gtwn 375
Fan does not work made strange noise then stopped
how do I get to the fan in the broom where is access so I can replace fan
glenn56h is offline   Reply With Quote
Old 04-11-2016, 10:24 AM   #89
Left Coast
Remove unit from RV and remove from housing to gain access to fans. Shut propane bottles off, light stove to empty lines....
Old 04-11-2016, 10:57 AM   #90
Flybob's Avatar
Running 2 Ceramic heaters on high will draw approx 25A. That plus the converter current will put you right at your limit. If you turn on any any additional appliances TV, microwave, heated bed, etc, you will trip a breaker if you have a 30A connection. . You can not count on running one of the heaters on the 15/20A outlet in the pedestal as in many parks, there is a 100A breaker up stream protecting 3 30A sites.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
furnace
