Forest River Forums
Sunline User Photos
Old 12-20-2011, 11:53 AM   #11
Decided not to go with a digital replacement thermostat since wiring is different and I'm not the world's best when it comes to that stuff. Anyway, got a replacemnt analog thermostat, same brand, same wiring. Changed it out and now the furnace comes on, no hot/warm air and shuts down in about 6 min. Same problem as before except I'm no longer getting hot/warm air during the time it runs for about 6 min. Any thoughts or suggestions??
BuckeyeByBirth is offline   Reply With Quote
Old 12-20-2011, 12:07 PM   #12
Dave_Monica's Avatar
Now it sounds like its not lighting...does the stove light? If your propane bottles have been shut off, open them very, very slowly and see if the furnace will light then.
Dave
2008 F250 CC SB 6.8L V10
2010 Rockwood 8280WS
Nights camped in 2010 - 58, 2011 - 43
Old 12-20-2011, 12:43 PM   #13
Propane Answer
Propane has always been on (I hadn't turned it off). I don't believe I even hear the clicking sound for it to light now whereas before it did.
Old 12-21-2011, 11:23 PM   #14
rracer5's Avatar
Originally Posted by BuckeyeByBirth View Post
I'm leaning toward replacing my thermostat. Are there digital models out there that will easily replace my analog stat? If so (or not) where's the best place to look for a replacement stat, either digital or analog, Lowe's, Home Depot, other??
Research this in detail. I don't think all furnaces are compatable with digital thermos unless you also do a circuit board upgrade on the heater to be compatable with the digital thermo. And the wiring is also more involved.
2011 RAM 2500 HD 6.7L CTD Crew, Reese Dual Cam Sway/Equalizer
2011 Lacrosse 303 RKS
Nights Camped;
2009 - 56, 2010 - 71, 2011 - 91, 2012 - 14
rracer5 is offline   Reply With Quote
Old 12-21-2011, 11:29 PM   #15
rracer5's Avatar
Recheck your wire connections to the thermostat. Sounds like you got the blower wires hooked up but maybe the burner control wires fell off?
Nights Camped;
Old 12-22-2011, 06:44 PM   #16
Burner Control Wire
Would the burner control wire you're speaking of be the one for "furnace?" These wires (not very big) are very touchy when feeding them into the "hole" on the thermo to then tighten them down. I'll check that wire but wanted to doublecheck back with you to make sure I'm concentrating on the correct wire. All other functions seem to be working, i.e., fan, fan hi/lo, and cool.
Thanks fro your input!
Old 12-22-2011, 10:59 PM   #17
rracer5's Avatar
Sound like a possibility. That wire may have a contact problem or fell off completely when you remounted to the wall. Good Luck!
Nights Camped;
Old 12-23-2011, 04:23 AM   #18
Mountainmanbob's Avatar
just some thoughts shared
Burner ignites - goes out after a few seconds
Possible causes:
  • low gas pressure
  • intake or exhaust vents obstructed
  • dirty burner
  • electrode(s) out of adjustment, dirty, or defective
  • bad control board
Definitions:
sail switch - micro switch with an arm that extends into the blower air stream which closes when the blower reaches approximately 75% of its rated speed. Also called an air prover switch.
limit switch - safety switch, a normally closed switch that opens if it gets to hot, opening turns off power to the gas valve and ignitor board
fan switch - a normally open switch that closes at a preset temperature, causes the furnace to run for a short time after the thermostat opens, allowing the furnace to cool down. time delay relay - same function as fan switch, only has its own heater, also used instead of a thermostat relay in newer models.
ignitor electrode - similar to a spark plug, 2 versions, 3 probe (remote sense) or 2 probe (local sense.)
ignition control board - when powered, initiates gas valve opening and spark sequence which lasts approximately 7 seconds. Older models are 1 try, thermostat must be cycled off for at least 10 seconds before another ignition cycle is attempted. Newer boards are 3 try, will attempt to ignite 3 times at approximately 60 second intervals.
Some furnaces now come with a fan control ignition board. Fan control boards will shut the blower down if ignition does not occur after 3 attempts. Some models will shut down the blower and wait an hour and recycle, if ignition does not occur the furnace is then shut down. Older DSI furnaces, with some exceptions can be upgraded to fan control. See Fan 50 Plus.
gas pressure - LP gas pressure must be 11" of water column (6.25 oz per sq. in.), checking and adjusting requires a manometer.
Marksrv.com rv furnace troubleshooting
Mountainmanbob is offline   Reply With Quote
» Online Users: 688
146 members and 542 guests
5Galvs, Alisa06, artnlisa, bagged123, BeagleIL, Bearcat55, bikendan, BlakeB, bo criswell, bob213, bob34787, boubou, brady, Buckeyecmpr, buckeyefan, Buffalohunter, Cafjackracing, Cascade Bob, cat1956, CCrane2299, cfsoistman, chof16, clarktod, ColoradoGreg, Cowracer, cstover, cyclepuck, danielpburke, danred, dapersico, DAREK.NIEUWSMA, Darren K, davidjb, dfrauhiger, djorgensen3, donn, drobert, duchie, dustman_stx, dville_v-lite, dwmangold, ecrissman, emljr, f1100turbo, Falcon35, Fire Instructor, Foneguy, Gary0848, gator14, h20ski, hairmommy, HemiCab, hokiecampers, hotrodj125, Iggy, iluvlcy, irish01, Italia2012, Itsthetwoofus, jamesroadking, Janet H, jar3316, jaydub3000, justinph, jwuertz, kegoneill, ken0042, KKapa, klucas, kybaja, KyDan, lbrjet, ldmcmahan, LFugate, lmcleister, lochsa, Lonewolfcry, lowbubba, Malco, manvel, Mark S, mhartzel, michaelpike, Mickey1, MIKE44460, milw156, MN128S, Mnflyboy, mtnguy, nailit, ncgrl1, OffPavement, PAMROBERTNC, pandkm, papap, PaulK, pchrcane65, Phil1, phone man, photog, pmsherman, popbreed, Ptmaazx6, racedaymechanic, RattVader, redfox217, Retired63, rickthelen, rkswyo, Rob H, Rogue69, SabreSam, sail2liv, Savage, scout800, SDENN4281, shane1234, shineysideup, shrimper, silly2635, SimchaSabre, skeeterbait8, skennedy, Snowsail, stevem4134, T.Kott, TacBear, tbritt, tedstr, texashatter, Timex, Titleguy, tlc, tmmar, travyp, Triguy, Vernk, Vette4trcr, vlite2011, wagon52, Warrior, wayne anthony, whj77372, william.migues, wolfpack21643, Zadnichek
Most users ever online was 944, 03-04-2012 at 01:27 PM.
Close [X]
