Old 08-12-2009, 10:50 PM   #1
diggerrv
diggerrv's Avatar
Question fussy generator
Proud owner of a new Forest River Georgetown, 340TS. It's a 2006 but new to me. My generator works great except when making left turns. It shuts itself off. I can restart it no problem. Checked electrical connections, OK. Any ideas?
diggerrv is offline   Reply With Quote
Old 08-12-2009, 11:06 PM   #2
Not familiar with that generator set up, but a few things in general. Turn the wheel to the left while sitting still. Try a very slow left turn. This should eliminate anything shorting out. Check fuel in generator tank. May be low and sloshing away from the fuel pickup point. Good luck.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 08-13-2009, 12:18 AM   #3
NWJeeper's Avatar
Generators in motorhomes have their fuel intake above the 1/4 mark on the main tank, therefore if you are low on gas or close to 1/4 and the fuel sloshes away from the intake the generator will loose fuel. Also, if it is an Onan I have found them to be a bit temperamental over time and may be in need of a good tune up. Could very well be a carburetor float problem.
Ed & Wendy
www.nwjeepn.com
Old 08-13-2009, 07:16 AM   #4
CLASS "A" Senior Member
cfsoistman's Avatar
In case you don't have the manuals for the generator which should be a Onan. here's a link to their site and you can look up any info about maintenance etc.
http://www.cumminsonan.com/rv/
I'd be interested to hear what the outcome is since we have a Onan as well.
Enjoy your Georgetown!!
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 08-13-2009, 12:34 PM   #5
diggerrv
diggerrv's Avatar
thanks for the info, full tank of gas, will not do it on a very slow left turn and this generator is a Guardian 6500. Any new ideas?
Old 08-13-2009, 12:42 PM   #6
cfsoistman's Avatar
Guardian is made by Generac. Here's a link to them. Maybe there's something there. Good luck!!
http://www.generac.com/RV/
Here's the link that Guardian is listed but for owner's manuals it will take you to the above website Generac Homepage.
http://www.poweredgenerators.com/guardian/rv.html
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 08-13-2009, 03:17 PM   #7
KyDan's Avatar
Most generators also have low oil cut off.
Are you sure it's absolutely up to the full mark on oil???
Old 08-13-2009, 04:06 PM   #8
ronhanson's Avatar
The Generacs have a diagnostic LED. Does it blink?
ronhanson is offline   Reply With Quote
Old 08-13-2009, 06:07 PM   #9
diggerrv
diggerrv's Avatar
Cool fussy generator
no light, Generac says they don't know???????
oil is good but now wondering if the oil level sensor may be bad.
Any thoughts?
thanks so much to all of you for helping.
Old 08-13-2009, 07:15 PM   #10
KyDan's Avatar
My bet is-- if it's not low fuel it's low oil or a low oil sensor.
Still just a guess.
