Old 03-23-2010, 05:24 PM   #1
W_A_Watson_II's Avatar
FYI: HTS-1500 Disc Region Fix/Work Around
Thought I'd share a bit of info I got as a result of trying to play some of our Region 1 DVD's in our New Silverback 29RE. Out of the first 5 DVD's we tried, three would not play and presented us with a Disc Region Issue. We know the DVD's are good, and work in all of our other players. Mike the Service Manager at American Coach got in contact with Forest River and provided me with the "HTS-1500 Tech Bulletin.pdf" that details the issue and how to work around it.
You can get a copy of it at the following Link: Region Error Technical Bulletin.
It seems to work, but take note in Technique 4's note 4 in reverse also. If the Disc has less that 16 chapters, the highest number in the "C" column will be the number of chapters. In my case I had a 15 chapter Disc, so the last column read 13, 14, 15, 15.
Hope this helps someone,
Will
2006 Dodge MegaCab 3500 DRW Cummins Powered with a B&W Companion and Turn Over Ball Hitches
2010 Forest River Cedar Creek Silverback - 29RE
W_A_Watson_II is offline   Reply With Quote
Old 03-24-2010, 07:14 AM   #2
Herk7769's Avatar
If all else fails, you have a computer with a DVD Burner, and you REALLY want to watch the movie; DVDFab works great. It will copy the DVD (Movie only or entire disc) to a blank DVD-R and remove the country code at the same time. No more issues ever.
Google DVDFab (Get the platinum version)
http://www.dvdfab.com/download.htm
Its free to try out for 30 days.
HAM CALLSIGN - KC3FFW
