Old 06-02-2008, 08:47 PM   #1
Galley Drain, garden or 3 in hose?
Our new Rockwood 8314SS has the usual black and grey tanks plus one for the kitchen sink. There is a separate 3 in drain for that under the trailer. Do I need to use a 3in hose or can I use an adapter and use a garden hose? I can screw that into the end of my regular sewer elbow which has a garden hose fitting on the back of it. Or should I use a 3 in with some type of y connector going into the sewer ?
hpage3 is offline   Reply With Quote
Old 06-02-2008, 09:04 PM   #2
Commercial Member
huntr70's Avatar
Most people just dump the one outlet and move the 3 inch hose to the second outlet when needed.
Steve and Vicki
2 kids
2011 Dodge 3500 CTD Outdoorsman
(Tweaked!!)
2013 Columbus 320RS-ITS HERE!!
huntr70 is offline   Reply With Quote
Old 06-02-2008, 10:27 PM   #3
I only dump my kitchen tank when needed, which is not very often. I carry two separate sewer hoses, one 10' and one 20'. I keep the one needed on the main tanks attached and use the other one as needed to dump the galley tank. Depending on the location of the sewer in the campground, it takes either the 10' or 20' hose.
Hokiehall is offline   Reply With Quote
Old 06-03-2008, 06:39 AM   #4
I have the same model but it is an 2006. Most of the time I use one hose and switch them out, I do have one extra hose and a tee if I want to hook them up together.
Old 06-21-2008, 07:16 AM   #5
We did the connector with the garden hose because we are on permanent site and it works great, hubby still cant understand that set up..good luck
blue eyes is offline   Reply With Quote
Old 06-21-2008, 07:27 AM   #6
wildwood's Avatar
3 inch drain quicker, but either works. it depends the frequency of dumping, if very often, a tee with an alternate hose to galley is nice, if once a trip, move your other hose when needed.
2008 Wildwood LE 29BHBS
wildwood is offline   Reply With Quote
Old 06-22-2008, 09:41 PM   #7
i switch mine also when i dump at a dump station i pull up so the dump hole is in between both valves so your hose should be able to reach without moving your camper
2008 8296SS Rockwood Signature Ultralite
2002 Silverado 2500HD extended cab
chevy02 is offline   Reply With Quote
Old 07-06-2008, 12:54 AM   #8
123
JAMES-JENNY-BABY GRAYSON
HDN OUT
2007 CHEVY 1500 TEXAS ADDN.
2008 SURVEYOR 303
surveyor254 is offline   Reply With Quote
