Old 09-24-2015, 08:24 PM   #1
mikkeeh's Avatar
Gas leak at water heater
Noticed a propane odor outside today. I had the water heater on " electric". It appears to be the gas valve is not sealing correctly and letting a small amount of gas though. It's enough to sustain a small flame at the orifice. I assume the fix is replacing the valve?? Are they rebuild able? Common issue?
Suburban 6 gal.
mikkeeh is offline   Reply With Quote
Old 09-26-2015, 11:37 AM   #2
mikkeeh's Avatar
Hmmm...guess its not too common.
Old 09-26-2015, 02:19 PM   #3
Head Rambler
Sorry this went without an answer, but you're right about it not being very common.
They're not considered rebuildable. It's best to just replace the valve.
Gotta go campin!
Old 09-26-2015, 02:56 PM   #4
Fred H.'s Avatar
X2 with Bama Rambler. It has to be replaced with a new valve.
Fred n Wilma
2017 Ford F-150 EcoBoost
2015 Crusader 295RST
Fred H. is offline   Reply With Quote
Old 09-26-2015, 03:15 PM   #5
Witch Doctor's Avatar
Suburban 6 gal.
Before you buy a new valve make sure you are getting the the correct voltage both on electric and gas. The valve is magnetic, so if your getting any voltage to it it will try and open. Check for any wires to it on the 12v. side and see if your getting anything if your not replace the valve. Also pull the 12 volt wires off and see if the flame go's away.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Witch Doctor is online now   Reply With Quote
Old 09-27-2015, 12:28 PM   #6
Location: Full timer,,,at Lake Georgetown in central Texas for the winter.
Mikkeeh.....the above is the best advice you're getting. I've been in the AC/heating and appliance business for 40 years, and this advice is right-on. Perfect advice.
Grampa Jim is offline   Reply With Quote
Old 09-27-2015, 01:05 PM   #7
B and B's Avatar
I am not a gas fitter or propane certified. But as Glen mentioned the valve can open with minimal voltage. Have you used the heater on propane lately?
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 09-27-2015, 02:27 PM   #8
mikkeeh's Avatar
The heater is used on propane on a fairly regular basis. I am assuming the solenoid is not closing completely. Ill get the meter out and check the voltage. Thanks for the replies.
Old 09-30-2015, 12:29 PM   #9
mikkeeh's Avatar
UPDATE: Changed the regulator and problem is solved. BUT, I found another problem. When i switched over propane tanks...the indicator showed my other tank was empty (or no flow). which in incorrect. So on to the next project!!!!
gas, heater, leak, water, water heater
