I purchased two Generac IQ's with a parallel cable to run my 15k AC. They wouldn't run my AC without popping their own breaker because of the way they responded to the AC cycling. I had to add the MicroAir easy start to use them. The IQ's would not cycle properly, meaning they don't respond fast enough to the load. Also when they do they speed up and then speed decreases, it then goes too slow. They work with the MicroAir but still don't respond well. If you are looking at gen's to run your AC, I would look elsewhere.
