What I would do is remove the air filter and spray gas (or starting fluid) in the carburetor while trying to start it. If it wants to start (it may only run for a second or two), then it's a good chance that it is a gas issue and not an electrical issue. Since it was already running, it's probably not a gummed up carburetor. It wouldn't hurt to give it a good dose of carburetor cleaner while you have the air filter off. If your generator has a sediment cup, remove and clean it. Also, if your generator has a fuel pump it may have gone bad. See if you can pull it off and test it. Good luck. Larry G.
2021 Silverado RST Z71 4x4 6.2L
2021 Flagstaff Micro Lite 25FKS
USMC (Retired) '70-91
