I have a 4000 W Champion generator that I previously used on my pop-up. When running it on the TT for the first time today, I noticed the power meter in the trailer was bouncing a bit, but still in the green. I took a video with my phone which can be seen here:
Is this bounce cause for concern? I've always hooked up to shore power, but would like to go dry this fall/winter in the desert - but I obviously don't want to fry any electronics or appliances!!
Thanks for any help you may be able to offer!!!!!
This is what the generator looks like:
These are the specs:
196 cc OHV Gasoline Powered Engine
4000 Peak Watts
3500 Running Watts
EPA Certified
CARB Certified
60 Hz Single Phase
AC Load 120/240 V
DC Load 12 V
Fuel Capacity 4 gallons (15 L)
Weight 99.2 lbs. (45 kg)
Height 18.1 inches (46 cm)
Width 18.1 inches (46 cm)
Length 24.2 inches (61.5 cm
