Old 03-20-2018, 11:32 AM   #1
zagain's Avatar
Smile Generator hookup - HELP!!
We picked up our first toyhauler, Vengeance 25V, 2 months ago and are still learning how to operate it.
We have a Powerstroke generator we picked up at Home Deport during the past hurricane season for household use. It is 6000 running watts generator. It has 4 L5-2R power outlets and 1 L14-30R power outlet. Can I use this generator on my toyhauler? Do I need to use any adapters? or do I need to get a different generator? What do the L14-30R code on the one power outlet means?
This is our first experience with trailers and want to make sure I don't do something wrong. Thanks.
zagain is offline   Reply With Quote
Old 03-20-2018, 11:49 AM   #2
dieselguy's Avatar
If you are talking about this genset https://www.homedepot.com/p/PowerStr...025A/203183991
1. You'll not be anyone's friend at a campground with this open framed generator howling away.
2. You can adapt down to any one of the four 20 amp 110 VAC outlets, but it'll be a strain to run an A/C and much anything else on that small of an extension cord.
3. I'm concerned with the advertising saying the 30 amp outlet is 240VAC. You don't want 240 VAC running to your RV like a stick house has.
Try looking over this link down to the very bottom of it. L just stands for locking. www.myrv.us/electric/Pg/30amp_Service.htm
dieselguy is offline   Reply With Quote
Old 03-20-2018, 12:37 PM   #3
DieselDrax's Avatar
I wouldn't bother using that with the TH for the reasons mentioned above. That's a big genny to only get 20A to your trailer and it's going to be quite loud. Not a big deal if you're dry camping with nobody else around, but if you have other campers nearby they're not going to like you very much.
If you want an RV generator that won't break the bank then check out the Predator from Harbor Freight.
https://www.harborfreight.com/engine...tor-63584.html
A comparable Honda EU genny will run about $2,000.
2017 GMC Canyon - CCLB, 4x4, 2.8L Duramax, ARE Z-series shell
2013 Shamrock 21SS
DieselDrax is offline   Reply With Quote
Old 03-20-2018, 12:54 PM   #4
They make an adapter to plug an RV style 30 plug to the 120/240 outlet on your generator. I'm not sure if yours has the 120/240 switch but my generator has a selector switch so I can use the full wattage from the 30 amp L14-30R outlet at 120V. That said, I would never use mine in a campground as it is loud. Was purchased primarily for power outages at the house.
2017 Avenger ATI 26BBS
2012 Chevrolet Surburban
jayrodoh is offline   Reply With Quote
Old 03-20-2018, 12:59 PM   #5
Prime Member
You will not make any friends using something that big and loud in a campground. Alot of campgrounds have limits on how loud gennys can be. Get yourself an inverting generator. They are alot quieter and produce power that's safe for sensitive electronics like laptops.
2016 Coachmen Freedom Express Liberty Edition 310BHDS
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Husky weight distribution hitch with sway control
timfromma is offline   Reply With Quote
Old 03-20-2018, 01:21 PM   #6
Open frame generators can indeed be noisy. A disqualifier for the close confines of a camp ground. OK for boon docking...
That generator can supply more than just a single 20 amp. An adaptor needs to be made or purchased to connect the trailer cord to the generator. Make sure to get said adaptor from someone who understands 99.9999% of trailers use 115VAC ONLY....NOT 230 VAC like a house!
LegacyFB38 is offline   Reply With Quote
Old 03-20-2018, 01:53 PM   #7
zagain's Avatar
Thanks.
Thanks everyone for the advices. Yes, that genny is pretty loud.
I will be getting the HF genny recommended above!
Old 03-20-2018, 01:58 PM   #8
Prime Member
Not true. 50A campers use 230VAC. The voltage gets split into (2) 120VAC buses inside the main breaker panel. Your house does the same exact thing.
Old 03-20-2018, 02:37 PM   #9
Originally Posted by timfromma View Post
Not true. 50A campers use 230VAC. The voltage gets split into (2) 120VAC buses in side the main breaker panel. Your house does the same exact thing.
Kinda yes, kinda no,
50A campers do indeed use both L1 and L2, but individually referenced to neutral (115VAC). Virtually NEVER across L1 and L2 (230VAC). Houses differ in that they actually use the 230VAC for things such as cloths dryers, ovens, central air...)
Said another way, 50A campers use two 115 VAC lines (L1/neutral/ground and L2/neutral/ground). So yes, both L1 and L2 runs to the camper, but it is never used as 230VAC. Only as two 115VAC lines.
To be precise, there is what I belief to be a very rare exception. Apparently SOME campers are known to use 230VAC. Presumably for an oven or cloths dryer, some other high power load. I've never seen this myself.
My real message here is be very careful wiring to a camper...more than one poor soul has plugged a camper into 230VAC. The usually happens when a 30 AMP camper receptacle gets wired like a household cloths washer receptacle. Not good!
Old 03-21-2018, 01:22 PM   #10
HF generator
If you have trouble making that HB gen. start, change out the spark plug to a known brand; that is what I had to do and found that suggestion on Goggle right off the bat. Myrt
br23mat8 is offline   Reply With Quote
generator
