Old 07-12-2019, 06:12 AM   #1
Generator size and number of deep cycles?
Edit to title: DEEP CYCLE..... not drop cycle. I can not seem to edit my title.
I'm not an electrician. I hate electricity once you leave the end user/consumer side of it.
Harbor Freight offers 2 units in quite inverter generators, a 3500 way for $699 with coupon and a 2000 watt for $449.
Obviously, I like the $449 price the most. But will that run my AC unit and keep my Apex Ultra Lite 289TBSS running along at a primitive camp site?
Also, the trailer is coming with a single deep cycle battery. I can't imagine that being overly useful.... Should I run to Rural King and grab 2 more of the $49 deep cycle that they have? I'm thinking that I can stack 3 together and batteries really shouldn't be an issue for a couple days or more?
2017 Ram Rebel 1500 5.7L / 8 Speed, Max Tow 10,160 lb / 1,075 lb payload rating.
2019 F-150 King Ranch 3.5 Eco-Boost 10-speed, 12,800 lb / 1,546 payload.
2020 FR Coachmen Apex Ultra Lite 289TBSS
2019 Quality Trailers 16'x7' 7K GVWR Utility Trailer
2019 Iron Bull 22'x102" 14K GVWR Equipment Trailer
2019 Kawasaki Mule Pro DX W/EPS and Yanmar Diesel 2,000 LB towing and 1,000 payload.
Larry0071 is online now   Reply With Quote
Old 07-12-2019, 06:38 AM   #2
We have a Honda EU3000IS generator with our 35' 5er that has 2 A/C units along with all the other normal stuff (e.g. microwave, TVs, etc). The generator will handle a single A/C unit (one is 15k BTU) but not both. And even when one is running, we have to be conservative with usage elsewhere (e.g. microwave, etc).
Personally I think a 2000 would be too small for your A/C unit and other items. 3500 should handle it well.
Lastly when it comes to generators, check out the dB rating. Some of them can be quite loud. We bought our Honda because we wanted/needed something quiet....and it is at just 50-57 dB. With it being so quiet, we can run in whenever and wherever (no worries about noise restrictions).
jd4010 is offline   Reply With Quote
Old 07-12-2019, 07:10 AM   #3
The Harbor Freight predator is also 57db. I've already searched out reviews and found really only great reviews, some owners saying that they are over 3,000 hours and running along just fine. The predator engine line from HF is reviewed very favorably and often compared to Honda engines being that it is a Honda clone engine.
https://www.harborfreight.com/3500-W...tor-63584.html
Old 07-12-2019, 07:15 AM   #4
Flybob's Avatar
The 2000 will be too small to reliably run the AC. If nothing else is running ( converter off) and the AC has been off for a while ( no pressure head) it will start and run, but this is not a real life situation.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 07-12-2019, 07:55 AM   #5
Good looking generator. I can see it being quiet with the enclosure and all.
Old 07-12-2019, 08:31 AM   #6
If you install a Microair soft start the 2K should run your A/C. Not a chance without it. Most of the 13.5 A/Cs draw in the 10-17 AMP while running, but the startup surge can be very high. Your would have to be careful with any other loads. Microwave and electric hot water heater would probably trip the overload protection on the generator. Curling irons, coffee pots, electric griddle/skillet probably would too.
NewBlackDak is offline   Reply With Quote
Old 07-12-2019, 09:04 AM   #7
Careful when purchasing "deep cycle" batteries. RV's typically come with dual use "boat" batteries that are not true deep cycle. At $49 dollars, I can guarantee what you are looking at is not what you want. Amp/hours are what you are looking for and campers usually either go with 2 12V in parallel or 2 6V in series which will get you around 215 amp/hours of which you can use about half until recharging is required. Costco carries the 6V "golf cart" batteries and Batteries Plus has all types. Look to spend around $100/battery. Lots of threads on batteries if you do a search.
Old- 2002 21 Roo
New- 2015 Shamrock 23 IKSS
TV- 2010 Nissan Titan CC
wharfrat48 is offline   Reply With Quote
Old 07-12-2019, 09:14 AM   #8
Fulltime family RVer
I started with a single Honda 2000. No soft start for the A/C. No nothing. Just the rig, the generator, and the family holed up at a port-o-pot lot dealing with some s**t.
Leading up to that point, I asked the same thing. I think it was TitanMike who said, ďitíll run it, but youíll hate it because it canít run anything else.Ē
In reality started the A/C most of the time *if* I had all of the other breakers off in the camper.
If you looked at the generator, the ďoverload lightĒ would temporarily light up. It was short enough that the generator didnít trip. But, reading the ownerís manual says this is hard on the generator. I do believe an EasyStart would be helpful in this case.
But, at the end of the day- the running A/C is taking up almost all of the available amps of the generator. The most important thing you wonít be able to run is the converter/battery charger. While running A/C, youíll be using battery power for lights and fans and whatnot. Itís not until you shut off the A/C will you finally be able to charge the batteries.
IMO, get the 3000W generator or get a pair of 2000s. A single 2000 isnít enough to comfortably run what you may need to.
ependydad is online now   Reply With Quote
Old 07-12-2019, 09:29 AM   #9
So is this RV/Marine battery not what your talking about?
https://www.ruralking.com/battery-24...cle-400cca-150
Or this smaller/cheaper "Marine" but not called out as RV one what your saying to stay away from?
https://www.ruralking.com/battery-525-cca-24-starting
Then the more expensive AGM RV/Marine option, would this be in the recommended type of battery.... Or the bad type of battery?
https://www.ruralking.com/battery-auto-agm-rk-agm24dp
Old 07-12-2019, 09:48 AM   #10
NMWildcat's Avatar
It is NOT a Honda clone. It is compared to a Honda, but so is every generator, as Honda is the gold standard.
It may seem cheap, but you get what you pay for.
If a Honda is out of your range, buy a Champion.
Also, take everyone's advice and buy two 2000s or one large enough to run your A/C AND some other stuff at the same time.
Two batteries and a generator is enough for boondocking.
Good luck and have fun!
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 07-12-2019, 10:03 AM   #11
You are going to get a bunch of opinions about generator brands and there have been literally thousands of posts on "best generator" on this site so I won't get into that. A search will give you days worth of reading for you to make YOUR decision.
A single 2000w generator won't do what you want without major compromise to what else you can run while on generator.
Get at least a 3000-3500w generator or two that you can parallel to get in that ballpark.
As for the battery... if your 12v demands are not all that high, it is very possible a single battery may get you through the day/night, along with running the generator during the recommended hours.
During the months we don't need the furnace (HUGE battery hog) we often can get through the day/night on a single battery (I have a selector switch and run off one at a time) with charging the battery during the day using the generator.
Days Camped: '16=46 '17=30 '18=51 '19=53
Old 07-12-2019, 10:06 AM   #12
Also, I have an article on generators. It can help with sizing, brands, and safety:
Learn to RV - Generators
Old 07-12-2019, 10:11 AM   #13
frank4711's Avatar
X2 On the Predator ...we have 4 in the family now
Frank & Cindy *** Rockwood Ultra Lite *** 2019 Ram *** Remi & Sage traveling Pomskies *** TST 507 TPMS *** B&W Patriot 18K *** 3.92 axle *** Goodyear Endurance *** 44 days camped 2019 *** Predator 3500
frank4711 is online now   Reply With Quote
Old 07-12-2019, 10:15 AM   #14
NMWildcat's Avatar
That's a GREAT article! Just enough good info w/o drowning you in details.
Thanks for sharing!
Old 07-12-2019, 10:49 AM   #15
Thanks for sharing!
Thank you for the kind words! I welcome any suggestions for improvements.
Old 07-12-2019, 11:15 AM   #16
Grammar Pedant
67L48's Avatar
A 13.5K BTU generator can demand up to 2,750 W on start up, and perhaps more. So, you either need to support that or get a soft-start cap to help.
Two things that I didn't see in the above referenced article.
First, when sizing a generator to your needs, you have to stay away from the big bold-faced power rating. That's misleading. If you need 2,000 W to run all your stuff, then a 2,000 W generator will be too small. The big loud number that's advertised is the peak rating and you're more interested in the nominal, continuous rating. For a 2,000 W genny, it's usually around 1,800 W. For a 3,500 W genny, it's usually around 3,200 W.
Second, while it's mentioned qualitatively, I think it's easy and important to factor altitude effects. All normally aspirated engines lose ~3% of power per 1000' over nominal (usually 500').
Let's say that you buy a Champion 3,100 W generator to camp with because it will meet that 2,750 W peak draw from the A/C start-up. Because it's a one-time hit, we can think in terms of peak rating ... the continuous draw of the 13.5K BTU A/C is a paltry 1,250 W.
OK, so when camping at the beach, you're golden. But, you also spend a lot of time at the Mojave desert at 5,000'. 4.5 * 3% = 13.5%. Your 3100 W generator will now give you around 2680 W. Will it run your A/C? Maybe. It's right on that border. Might fire up. Might trip a breaker on the genny.
I camp at 9,500' regularly, sometimes higher. At that point, I'm losing 27% of my generator's power. What size do I need to still hit 2,750W? 2750/.73 = 3,767 W. So, I sort of need a 3,800 W generator to reliably start my A/C at altitude. Yikes!
RV: 2018 Rockwood Mini Lite 2504S
67L48 is offline   Reply With Quote
Old 07-12-2019, 11:16 AM   #17
Those are not true deep cycle - one way you can tell is they have Cold Cranking Amp specs (CCA) these are designed to start an engine and have some reserve capacity- You want to find a spec for Amp/hours. Search Trojan T-105, this is a 6V golf cart battery commonly used for deep cycle RV applications (need two in series to generate 12V)- it has 225amp hours. Of course, your 12V electric requirements will determine what size battery bank you need. If you will always be connected to shore power and/or be running your generator, the single battery that comes with your RV should be fine. If you want to camp for days without your generator or shore power, you would need a larger battery bank. How large depends on your electric usage and ability to recharge your bank (solar/generator/shore power). Search for the "12volt side of life" for some good info.
Old- 2002 21 Roo
Old 07-12-2019, 11:32 AM   #18
Of course, hopefully you would never A/C at 9500'.
2017 Coachmen 233RBS
2018 Ford F150 Lariat 3.5 Eco
"Common sense is not very common"
babock is online now   Reply With Quote
Old 07-12-2019, 11:42 AM   #19
Grammar Pedant
67L48's Avatar
Was just at Mueller State Park at 9,400'. It was 83 and sunny, which put the inside of the trailer in the upper 80s. We had shore power and the A/C felt great.
Old 07-12-2019, 11:48 AM   #20
I would never run AC in the 80s. I have a house in lake Tahoe at 6200' and I don't even have an AC in the house. In fact only 1 out of 30 houses in my neighborhood have them.
generator
