Old 09-12-2016, 08:10 PM   #11
Bluepill's Avatar
Originally Posted by Lodie View Post
Do I really need that thing
It's way more important in and RV than in a home. If there is leakage from the HOT side of the circuit to the frame of the RV, just touching any metal on the RV while standing on wet ground could electrocute you. Really.
2008 Itasca Meridian 37H
Old 09-14-2016, 03:14 PM   #12
There is another way, you can change each receptacle to an individual GFCI by making the entire circuit a feed thru. You do have to change the way the circuit feeds each receptacle or it will not work.
Rich5117 is offline   Reply With Quote
Old 09-20-2016, 09:10 PM   #13
gfci problem fixed
I just want to thank all of you good folks who tried to help me with this problem. I was SO close to actually fixing it myself when I went and bought and installed a new GFCI receptacle. However, it still wouldn't reset. Well, my good friend who knows a little bit about everything came over today and found out what I'd done. When installing the new receptacle, I had put the "line" where the "load" needed to and vice versa. As soon as he reversed the wires it reset and all my other receptacles came to life. Thank the Lord who know what the heck they are doing. Thank you all for trying to help me here.
Lodie is offline   Reply With Quote
electrical
