Old 09-12-2016, 12:48 PM   #1
Gfci outlets
Camping now. Gfci outlet will not reset. Have reset breaker but still won't work. Should I just change the thing
Lodie is offline   Reply With Quote
Old 09-12-2016, 12:57 PM   #2
Is anything plugged in 'downstream' of the GFCI that would be causing it to not reset?
Most GFCI's protect several other outlets throughout the camper.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
2016 Nights Camped = 46
Old 09-12-2016, 01:00 PM   #3
Nothing is plugged into any of them
Old 09-12-2016, 01:23 PM   #4
I had a downstream outlet in my side compartment that was mounted to the wheel well. After driving in a storm my gfi in the kitchen would not reset. Traced it to water infiltration at the downstream outlet. Disconnected it and was able to reset the gfi. The outlet had screws that went completely through the wheel well allowing the spray from the tires to soak through.
Paul S. is offline   Reply With Quote
Old 09-12-2016, 02:07 PM   #5
It could be this outside outlet. Lots of rain lately and I washed the camper. Trying to dry it with hair dryer.
Old 09-12-2016, 02:58 PM   #6
Quite likely.
Outside outlets are protected by an interior GFCI outlet.
Water in an outside outlet (as mentioned above) would cause the interior GFCI to not reset.
Old 09-12-2016, 05:15 PM   #7
Do I really need that thing
Old 09-12-2016, 07:47 PM   #8
Yes.
Old 09-12-2016, 08:04 PM   #9
Ret E-9 Anchor-clanker
donanddona's Avatar
Replace it. Keep your receipt. If needed return it. At least you'll know if that's it.
donanddona is offline   Reply With Quote
Old 09-12-2016, 08:10 PM   #10
Yeah.
GFCI receptacles can protect you from faulty devices, however they most often come into play in wet areas.
If your GFCI is functioning correctly and is tripping, be happy you have it.
Whom ever suggested the outside receptacle made a good call... especially if it has been raining.
325BH is online now   Reply With Quote
electrical
