Old 04-23-2015, 08:44 PM   #1
Grey overflow
I have a 2015 mini lite 2306.
While pulling out of my campsite on a fairly steep hill I stopped momentarily to check things out and noticed a steady drip from the upper half of the grey tank. The tank was 2/3 full when level.
I'm wondering if there is an overflow on the top of the tank and the incline forced some out? Or should I investigate further for a leak?
Thank you for input.
nickrez is offline   Reply With Quote
Old 04-23-2015, 09:14 PM   #2
vinmaker's Avatar
I do not think there should be any water leaking out when you climb a hill. I am thinking you should look for a leak.
Vin.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 10000#
Old 04-23-2015, 09:21 PM   #3
Grey overflow
It's going in for service tomorrow for a leak around the bathroom vent fan so I'll be asking about the grey tank as well.
I'll post my results for anyone else coming across a similar issue.
Thanks vin
Old 04-24-2015, 08:52 AM   #4
Ur gray tank shouldn't have an overflow cause if it did why have a holding tank at all. Check for a leak in the plumbing or tank it self.
kinma13 is offline   Reply With Quote
Old 04-24-2015, 11:10 AM   #5
Just picked up my trailer from service. Had the bathroom vent fan sealed under warranty. The technician noted that the factory neglected to install any sealant by the fan bracket. Caused leaking and some minor ceiling trim damage.
About the grey tank:
Tech informed me there is an overflow at the top of the grey tank. I was surprised.
It's an easy explanation for the dripping I saw. I hope it is the case.
Old 04-24-2015, 12:19 PM   #6
Wonder why have a gray tank then. Cause if you fill it it will just flow out n on the ground so it never fills?? Why just done use one and let it flow on the ground?? Lol
Old 04-24-2015, 12:48 PM   #7
I suppose it's to prevent accidental overflow into the trailer? Like the fresh tank overflow.
Old 04-24-2015, 12:53 PM   #8
Never heard of a grey water overflow. I think the tech was blowing smoke!
Old 04-24-2015, 01:13 PM   #9
It's certainly possible the tech was blowing smoke, but why?
In any case, I'm planning to somehow confirm.
Old 04-24-2015, 01:17 PM   #10
To keep from having to find the leak.
Old 04-24-2015, 01:28 PM   #11
Agree with OC
Old 04-24-2015, 01:29 PM   #12
Well I submitted an inquiry to FR directly. I'm curious to find out
Old 04-24-2015, 01:48 PM   #13
vinmaker's Avatar
Omg. I want one of those tanks. A grey tank that never fills up is a great invention.
Wonder if I could just core a hole into mine as a DIY overflow project. lol.
Vin.
2015 HW296
2013 Chevy Tahoe
Old 07-08-2017, 09:58 PM   #14
Exclamation Gray Water Tank Overflow
Did you ever get a response from FR about the gray tank overflow?
I seem to be having the same issue with my 2017 Sportscoach.
Wondering if anyone has tried to attach a drain hose from the overflow to the bottom of the coach rather than just filling up the basement with water.
When it first happened, I thought the fresh water tank was leaking, confirmed later that it was the gray tank overflow. Stupid thing just empties right into the basement area where the city water hookup and waste gates are located. The ends up on top of the fresh water tank (top indented) located below the gray and black tanks. When you leave your site, the water ends up poring out of the metal frame and looks real bad.
I have since learned not to wait until the monitor says "full" as by then its too late. I now drain the gray water at two-thirds full and haven't had any issue since.
Note: the gray water did not back-up into the shower as some other threads suggest is suppose to happen. I think the overflow is on top of the gray tank and is not part of the vent pipe system.
mmcbride56 is offline   Reply With Quote
Old 07-08-2017, 10:55 PM   #15
King of the Road
As I stated on your thread here http://www.forestriverforums.com/for...ix-138776.html
I don't think you have an overflow on gray/black tanks. If they get too full they should be backing up into galley, bath or toidy. RV parks and national/state parks would have a fit if unattentive or careless campers let those tanks leak out onto their ground.
I think there is a different problem, maybe the tank is cracked or the vent/drains into the tank?
Something is not kosher
2016 Crusader Lite
Single slide
2013 Ram 2500 Crew Cab Tow Vehicle
2016 days camped = 91, 2017 days camped = 109
Dano1955 is offline   Reply With Quote
