Originally Posted by nickrez
Well I submitted an inquiry to FR directly. I'm curious to find out
Did you ever get a response from FR about the gray tank overflow?
I seem to be having the same issue with my 2017 Sportscoach.
Wondering if anyone has tried to attach a drain hose from the overflow to the bottom of the coach rather than just filling up the basement with water.
When it first happened, I thought the fresh water tank was leaking, confirmed later that it was the gray tank overflow. Stupid thing just empties right into the basement area where the city water hookup and waste gates are located. The ends up on top of the fresh water tank (top indented) located below the gray and black tanks. When you leave your site, the water ends up poring out of the metal frame and looks real bad.
I have since learned not to wait until the monitor says "full" as by then its too late. I now drain the gray water at two-thirds full and haven't had any issue since.
Note: the gray water did not back-up into the shower as some other threads suggest is suppose to happen. I think the overflow is on top of the gray tank and is not part of the vent pipe system.
